netrati Posted June 25, 2003 Share Posted June 25, 2003 Hey I got a few questions for you guys. I just bought a 1989 GTS-t. It has aftermarket exhaust, intercooler, intake, bov, and tuned computer. The deal is it idles kinda rough and when you let off the gas after revving it up the RPMs drop way low like 450 or so, it almost stalls. Another thing is horrible, I mean awful performance. I tested it from 0-100km/h and it took 8.869secs!!! Not anywhere close to stock! I'm hoping that it needs a tune-up really bad. Maybe a fried spark plug or a bad ignition coil. Could one of these things cause the performance to be that bad? Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/ Share on other sites More sharing options...
SLY33 Posted June 25, 2003 Share Posted June 25, 2003 your nearly stalling problem after revving it up is due to the BOV. the spring tension needs to be increased a bit, simple fix if your bov is adjustable. Sounds like you need to get a good tune - theres no way you can be in japan?! why on earth would you need advice from australia? And you no write broken englis. Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-402230 Share on other sites More sharing options...
netrati Posted June 25, 2003 Author Share Posted June 25, 2003 HAHA very funny. I'm not for sure if the BOV is adjustable, it's an HKS one. I'm an american that's why my english isn't broken and I can't exactly get help here in Japan b/c I don't speak Japanese. I hope a tune-up does the trick. Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-402276 Share on other sites More sharing options...
netrati Posted June 25, 2003 Author Share Posted June 25, 2003 Can someone explain to me why exactly not enough spring tension in the BOV causes the car the stall after high revs? Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-402309 Share on other sites More sharing options...
BigDatto Posted June 25, 2003 Share Posted June 25, 2003 check this thread: http://www.skylinesaustralia.com/forums/sh...s=&threadid=408 curiously, changing to copper plugs gapped @8mm fixed my stalling problem - so it seems it could be any one of three issues BOV, fuel pressure or in my experience, plugs ! must be difficult for you not speaking Nihongo... Good Luck with it. Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-402326 Share on other sites More sharing options...
Ronin 09 Posted June 25, 2003 Share Posted June 25, 2003 hmmm, 8mm gap eh? i assume you mean 0.8mm sorry couldn't resist, no offense intended Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-402403 Share on other sites More sharing options...
BigDatto Posted June 25, 2003 Share Posted June 25, 2003 10-4 Copy That !! Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-402410 Share on other sites More sharing options...
Cool Hand Luke Posted June 25, 2003 Share Posted June 25, 2003 When your car idles, do your revs fluctuate? By that i mean for 15secs its at 800rpm, next 15 secs its at 1200? Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-402450 Share on other sites More sharing options...
netrati Posted June 26, 2003 Author Share Posted June 26, 2003 No the revs don't fluctuate that much. When I first turn in on they are usally high, somewhere around 1200RPM. After a few mins when the car warms up they drop down to 800RPM. Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-402600 Share on other sites More sharing options...
Steve Posted June 26, 2003 Share Posted June 26, 2003 netrati, have a look at this thread: http://www.skylinesaustralia.com/forums/sh...s=&threadid=408 could also be the problem at low revs. Plugs never hurt, esp as NGK coppers are about AUD$20 a set, clean your afm, change the fuel filter and reset the ecu - different car (hopefully) Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-402627 Share on other sites More sharing options...
netrati Posted June 26, 2003 Author Share Posted June 26, 2003 Got the car back from the shop today. It seems as though my mine's tuned computer bit the dust and it was only firing 5 cyl. Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-403444 Share on other sites More sharing options...
Nick Posted June 26, 2003 Share Posted June 26, 2003 I had dramas with the previous owner's adjustment on my Blitz BOV, a simple tweak and she was running sweet. But now that I've just plugged in the Power FC (yet to be tuned), yeah I get higher revs when first turning the car on (like 1400rpm), but it rarely comes back down to where it would ordinarily idle wehn warm on the stock computer (700rpm). And when decelerating coming up to a roundabout for example at 30km'h in 2nd, as I exit the roundabout my revs will rise and I can actually increase my speed without touching the accelerator. I know the base program is not so great - typically running rather rich - but is the car feeding more fuel to the engine and at the same time being misread as throttle when the clutch is out and my foot's off the accelerator? WTF? The mind boggles. There I go, having a spit when all it probably needs is a tune... Anyone ever experienced anything similar though? Cheers! Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-403547 Share on other sites More sharing options...
bryanlee38 Posted June 26, 2003 Share Posted June 26, 2003 OMG. u're in japan! Can u get me some parts? - I hear 18" rims r only $400/$500 there 2nd hand. I want some! lol. Back to ur question. my bov did the samething. after like 2 weeks, i reset the ecu once too, everything was fine. Guess i was just lucky. anywayz how about those rims I'm pretty sure there will be a few guys in Japan who can help u out - $ is an universal language of requiring their services. Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-404028 Share on other sites More sharing options...
netrati Posted June 27, 2003 Author Share Posted June 27, 2003 HAHA probably not even $400. Cars are super cheap here. There was a 1991 Skyline GTS-t with an aftermarket turbo, exhaust, clutch, injectors, pump, and all other kinds of stuff for $4800. Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-404703 Share on other sites More sharing options...
Ronin 09 Posted June 27, 2003 Share Posted June 27, 2003 i think i offer a collective "we hate you" from everyone here in Aus who can't get a modded GTSt for 4800. Good luck with getting your car running properly! Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-404771 Share on other sites More sharing options...
bryanlee38 Posted June 27, 2003 Share Posted June 27, 2003 so how about it bro. I'll deposot Aus$400 in ur bank a/c. ship me a set of 18's (white ones) and u can keep the change kekekeke. I know its off the topic ... but I NEED RIMS. I HATE MY STOCK ONES! Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-404887 Share on other sites More sharing options...
Guest RedLineGTR Posted June 27, 2003 Share Posted June 27, 2003 dam i'm going to japan...lolz Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-404911 Share on other sites More sharing options...
netrati Posted June 27, 2003 Author Share Posted June 27, 2003 I'll check the prices of 18" rims Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-405354 Share on other sites More sharing options...
Cool Hand Luke Posted June 27, 2003 Share Posted June 27, 2003 Can you get me a turbo? HKS2530 to be specific Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-405452 Share on other sites More sharing options...
red17 Posted June 28, 2003 Share Posted June 28, 2003 Hey netrati, Are you part of the american military over in japan? I hear theres a bunch of Marines on bases over there who are right into drifting etc. Red17 Link to comment https://www.sau.com.au/forums/topic/19141-horrible-performance/#findComment-405975 Share on other sites More sharing options...
