hey guys,
Not sure, but probably has been thought of/or done, but was thinking about getting two apexi pods and putting them on my R34 Gt-t. obviously its only a single turbo so would there be any benefit by somehow cutting a hole in the pod filter piping, joining a pipe with another pod on the end of the it so there is the dual intake? i hope u get what i mean haha let me know wat ur thoughts are.
Regards,
Mitch
https://www.sau.com.au/forums/topic/191415-dual-pod-filter/
dude i wouldnt even bother, for the amount of stuffing around to get two to fit its not worth it. just have one with CAI and shield from engine heat. one with CAI and boxed would be better than two pods breathing hot air.
Edited by Fadie
https://www.sau.com.au/forums/topic/191415-dual-pod-filter/#findComment-3444169
aww hahaha it was worth a try...just thought would be good cause its inducting twice as much air
Would it be sucking in twice as much air?
Or would each pod filter be sucking half each of what the original one was? :P
"It makes you Think" (you'd probly need to be a Kiwi to get that :) )
https://www.sau.com.au/forums/topic/191415-dual-pod-filter/#findComment-3447026
hmm i would think that it would be double the air...makes sense cause there is twice the induction...its like single turbo and twin turbo. but i yea it could be taking away from the other...i guess if u dyno'd it and tested the difference?
https://www.sau.com.au/forums/topic/191415-dual-pod-filter/#findComment-3447802
The theory is there, but if your Turbo is boosting at 9psi and is limited to that via a solenoid or boost controller, then the limit will still apply, each filter will just be doing half the work.
Does adding a 3rd pod filter triple the intake capacity? I wouldnt think so.
And in the case of a twin turbo, each turbo has its own filter. Totally different scenario!
Edited by gotRICE?
https://www.sau.com.au/forums/topic/191415-dual-pod-filter/#findComment-3448839
mmm true...just seeing one pod filters difference compared to a stock filter gave me the thought that it may be useful to apply twooo pods :) owel will have to brainstorm for another way to produce powaaaa lol
https://www.sau.com.au/forums/topic/191415-dual-pod-filter/#findComment-3449488
I think you've got your words mixed. Having one pod filter may give you sufficient airflow. Increasing the number to two doesn't mean that the engine will need anymore air at any given point, therefore it will not suck in twice the amount of air. What you have done is double to airflow capacity.
There may be a little gain in power as each air filter does not have to work as hard to pull in the required amount of air, i.e. having two air filters may have a beneficial impact on inlet restrictions.
https://www.sau.com.au/forums/topic/191415-dual-pod-filter/#findComment-3450323
Its just a cheap method for not having to upgrade your AFM but you will need the a/m hardware to get it going in the first place. I believe it can be done with a cheaper SAFC2
Having the two pod pipes halves the restriction through the afm intake hence you can double its potential airflow (potentially halving its full flow resolution) and still metre the correct air.
Ok in simple terms. Driving down road with one AFM, flowing enough air to register +1v. Now driving down with two, you know you have twice the airflow at +1v. Retune to suit - simple!
pod-------afm------========== tb
pod-----------------'
Edited by Jmaac
https://www.sau.com.au/forums/topic/191415-dual-pod-filter/#findComment-3451465
How the heck did you come up with that?
You can't have dual intake pipes with dual pods with only one AFM on one intake pipe. You said before that your bypassing the afm "halves the restriction through the afm intake hence you can double its potential airflow".
All the air has to be metered. Non of it can be bypassed. Having a SAFC tricks the ecu into thinking there is less air, but it is all metered and controlled by the safc.
Bypassing the AFM gives you no control over the afr's as it will be sucking in un-metered air and giving you a potentially dangerous and uncontrolled lean out situation. What if the unmetered pod sucks in more air than it usually does? It'll lean out.
If this mod were true, no one would be buying z32 afm's to get past the limit of the standard afm if you could potentially double its resolution.
It's like putting a massive 3" hole in the side of your standard intake pipe and putting a filter on it, and "retune to suit".
Explain if I've missed something please.....
Edited by KeyMaker
https://www.sau.com.au/forums/topic/191415-dual-pod-filter/#findComment-3451608
Think of it this way, if you have no piping or filter or anything on ur turbo, just the turbo intake (like drag cars run), then ur turbo sucks in as much air as it needs. If you have a pipe coming off of this turbo(providing its the same size pipe as the turbo inlet), it still sucks the same amount of air, just at the end of the pipe. Now regardless what you put on the end of this pipe, single filter, two filters, or whatever, it is still sucking the same amount of air.
If that doesn't make sense think of it as a human sucking through a straw, single big straw, u suck up as much as you can and it's your lung capacity (ie the turbo) that limits how much you can suck, sucking through two straws, doesn't magically allow you to suck double the amount of air, just means half is going through each straw.
So yeah, two pods will not help :D
https://www.sau.com.au/forums/topic/191415-dual-pod-filter/#findComment-3464830
    • Crazy how good the aero bar looks compared to the stock one
    • Yes, but you will need to rewire all the things that are different. CAS, coils, etc. Yes, but there is no IAT. What? You can use anything you like. It just has to be hooked up so that it will work.     Or are you wanting to just plug and play without having to do any thinking/work?
    • It's been a little over a decade since I bought the S15. As I did on my socials, I'll share some of my favorite pictures from over the years further below. If you haven't realised, pretty much all the pictures in my posts are ones I've taken.  In terms of updates, I don't have pictures, but I acquired a near-perfect pair of fog lights from a friend of mine, so those got swapped in for the pair I already had. As for the JZX110, I just got it back from being fixed. A few weeks back, I was on the highway when I suddenly drove over something with very little time to react. It was probably the size of a soccer ball, but it went under the car and banged into the underside pretty loudly. I pulled over and realized the fluid leaking was fuel, and of course, it was right near my exhaust. This required replacing the fuel tank. If you happen to be in the same predicament, thankfully this car shares a fuel tank with the JZS171, IS200, and IS300, so it wasn't too painful to replace. Enjoy some pictures as mentioned above, including the carnage from the fuel tank and a bonus picture I came across which shows how ridiculously shiny the Bugels are on the 110. So many more pictures I could share of the S15 but this will do for today, enjoy.
    • Welcome.  Was the mistake the car, or joining us? 馃槒
    • Yeap, was me and the daughter getting coffee before heading to the new joint to measure up the fridge space and taking some pics that the solar installer wanted of the switch board
