looks like mine is a fuel problem cos my car has big trouble starting now if i get it going :) tried to start it this arvo and first try it chugged a bit and died, second try the chugging got slower then died, third time i got nothing at all lol. a mate of mine reckons my aftermarket fuel pump has died, not sure when it was fitted as i bought the car with it on.
my mods are FMIC, cat back exhaust, bigger fuel pump, electronic boost controller, K&N filter and runs about 13psi but cant hold it the whole way so drops to 11psi and greddy bov.
the car goes into hyperdrive in 2 weeks to see if they can find the problem. any ideas or info would be greatly appreciated!!
  • Replies 41
My mods are only pod filter, 3" cat back exhaust and just installed an fmic... the popping / spitting / misfiring i described in my previous post seems to have begun since i installed the fmic.. don't know if they are related or whether the better air flow has just allowed something which wasn't working properly to have it's weakness exposed.
Missed with stock coils at around 4500 rpm (PFC) - like hitting the limiter, it pops and misses etc
have to admit this sounds most like my problem. Hoping it's not coz i don't have a spare $500 on me at the moment. Could the same issues be caused by something as simple as shitty spark plugs or plug leads?
Do speedworks have a dyno? may need to put the car on the dyno to diagnose it since the problem only happens under load.
Update on my car's issues:
Upgraded fuel pump to one from an R33 GTR - no change
Replaced spark plugs - no change
i don't regret doing either thing though because the better pump will be good for future tuning and the spark plugs really did need replacing..
one thing i learnt from the old spark plugs is that they look as if the engine has been running on the leaner end of the scale.. suggests towards a fuel issue rather than ignition.. Gonna check the fuel pressure regulator tomorrow to see if that's all working fine... if i can't find out i'll probably book it in at speedworks and get them to diagnose it.. either the engine is not getting enough fuel or it's not igniting while under boost. Pop pop.
can't shake the feeling in my gut that it's coil packs though.
Is it normal to have some oil coming through my air pipes after the turbo, and how much is normal?
i don't think i have a lot coming through, but when i was changing my intercooler i had some dripping out of a disconnected pipe (like 5 or so drips) and one of the new cooler pipes which wasn't tightened properly for a lil while had oil come through the leak.
could this be the source of my problem? is my turbo screwed? .. it appears to be working fine.. still get about 12 psi or so
Mate thats probably just blow by and as long as there is not a lot of oil (5 or so drips is nothing) it isn't much to worry about.
  • 2 months later...
hey guys i have tried a few things with my car to try and fix the problem but it seems to be worse now all of a sudden the car will start jerking back and forward usually around 2500 - 3000 rpm i have bought and installed splitfire coilpacks as well as install a bosch 040 and new fuel filter and cleaned out the afm with electrical contact cleaner, after i cleaned the afm it ran really well for about half a day then started screwing up again could it possibly be that my afm is screwed?
Dude,
its your AFM, have a look, I posted a similar problem about 6 months or so ago...
Although I have an R33gtst.
Have a look at what type of air flow meter you have, and borrow one off someone to try... I think the RB25 has 3 different stickers on them a pink, yellow and green.. I could be wrong with the colours.. but yeha mine had a pink one.. I borrowed an AFM, put it on my car, and she was sweet.. Then had a look on the for sale section and managed to get one for $100.. The car never missed a beat after that... I would also suggest having a look at the posts about coilpacks. and how to fix em.. i found mine had some of those hairline cracks.. also worth doing...
I tried cleaning the AFM before too, and it worked for a little while.. but after realising the way a AFM works, I realised the thermistor had just got old, and needed replacing.. if you wanna pull your AFM apart, check for dry joints, there is a thing on the forum on how to do it.. But yeah I donno if it is possible to get the thermistor specs for that type of AFM.. I mean you could measure it, but I doubt you'll be able to match it..
The AFM should solve your issues for now though..
Good luck
Cheers,
maka.
Edited by maka
thanks mate bubba said i could borrow his to see if that fixes just waiting to hear back from him, it if it does ill see if he will sell it to me if he wont ill upgrade to a z32 afm
cheers again
cheers again
Sweet, no probs. see how you go.. But isnt Bubba running a RB30/25 or something in those lines?
Yeah, as long as it is the same one, you'll be ok.. I mean if worst comes to worst, you can just get another 3 pin AFM, find out the pin config, and put that on.. I remember using a AFM of some sort of subaru... was a lot larger than the one that is standard on the 33.. Car took forever to get up to speed, but it proved the AFM was an issue...
Cheers.
I had exactly the same issue.. Turned out to be the crank angle sensor.. it definately is possible that it's the AFM, but there are a few sensors that can cause these sorts of problems.
Allstar Garage did a great job of diagnosing it.
yeah im going to borrow bubbas afm on sat to see if that is the problem hopefully this will fix it cause its really frustrating having to baby my car around everywhere ill let you know how it goes
the solder points inside the afm probly broke apart, same thing was happening to me i wud be driving along and then car wud shudder and jerk back and forth under acceleration,(r33 tho)
dont throw the afm out dude, it can be fixed
u have to get a stanly knife and cut the silicon seal around the side cap out, take that off and u shud see a copper plate, remove that and u will be able to see the circiut board and there will be three metal pins that join up to another set leading down to the fillament, the solder used to join these is shit and breaks easy, so just get some more and resolder them, i made sure ther were lots of solder on each connection so they dont break again, then just put the copper plate back in, put the side cap on and reseal it with silicon again (i used sensor safe black rtv silicon) and voila car drives normal again.
okay i might do that tonight then and keep it as a spare cheers
Cheers.
Indeed I am, but I am also running a z32 afm and have lots of RB20 crap lying around :blink:
    • Or just wire a multimeter in, sit it up like it's a gauge, go for a drive, read temp gauge, read multimeter, speak to phone and tell it to take notes.
    • This is the other log file, if only we had exhaust manifold pressure - would understand what's going on a bit better   Can you take a screenshot of your wastegate setup in the Kebabtech?   Engine Functions --> Boost Control (looks like this):
    • You just need a datalogger of some sort. A handheld oscilloscope could do it, because it will make the trace visible on screen, so you can look at the peak, or whatever you need to look at. And there are cheap USB voltage loggers available too. You could get a 2 channel one and press a button to feed voltage to the second channel at points that you want to check the sensor voltage, when you knew what the guage was saying, for example.
    • it's not the issue with making power, it's the issue with controlling boost, and this isn't the first time I've seen a 6Boost having issue with controlling boost down low.   The boost control here looks interesting.   Looking at your logs, looks like it's set to open loop boost control strategy (which is fine). We can see VCT being kept on till about 6600RPM (no issue with that). Ignition timing (I'm assuming this is E85, seems within reason too, nothing too low, causing hot EGTS and boost spiking). There's about 15 degrees of advance when your boost shoots up, however can't be this as the timing isn't single digits. I'm assuming there's no EMAP data, as I wasn't able to find it in the logs. We can see your tuner sets the WG DC to 0% after 4300RPM, trying to control boost.   My thoughts, what frequency is your wastegate set to?  AND why aren't you using both ports for better control?
    • While that sounds reasonable, this is definitely a boost control problem, but the real question is why are you having the boost control problem? Which is why I pondered the idea that there's a problem at ~4000rpm related to head flow. In that instance, you are not yet under boost control - it's still ramping up and the wastegate is yet to gain authority. So, I'm thinking that if the wastegate is not yet open enough to execute control, but the compressor has somehow managed ot make a lot of flow, and the intake side of the head doesn't flow as well as the exhaust side (more on that later), then presto, high MAP (read that as boost overshoot). I have a number of further thoughts. I use butterfly valves in industrial applications ALL THE TIME. They have a very non-linear flow curve. That is to say that there is a linear-ish region in the middle of their opening range, where a 1% change in opening will cause a reasonably similar change in flow rate, from one place to another. So, maybe between 30% open and 60% open, that 1% change in opening gives you a similar 2% change in flow. (That 2% is pulled out of my bum, and is 2% of the maximum flow capacity of the valve, not 2% of the flow that happens to be going through the valve at that moment). That means that at 30% open, a 1% change in opening will give you a larger relative flow increase (relative to the flow going through the valve right then) compared to the same increment in opening giving you the same increment in flow in outright flow units. But at 60% opening, that extra 2% of max flow is relatively less than 1/2 the increase at 30% opening. Does that make sense? It doesn't matter if it doesn't because it's not the main point anyway. Below and above the linear-ish range in the middle, the opening-flow curve becomes quite...curved. Here's a typical butterfy valve flow curve. Note that there is a very low slope at the bottom end, quite steep linear-ish slope in the middle, then it rolls off to a low slope at the top. This curve shows the "gain" that you get from a butterfly valve as a function of opening%. Note the massive spike in the curve at 30%. That's the point I was making above that could be hard to understand. So here's the point I'm trying to make. I don't know if a butterfly valve is actually a good candiate for a wastegate. A poppet valve of some sort has a very linear flow curve as a function of opening %. It can't be anyelse but linear. It moves linearly and the flow area increases linearly with opening %. I can't find a useful enough CV curve for a poppet valve that you could compare against the one I showed for the butterfly, but you can pretty much imagine that it will not have that lazy, slow increase in flow as it comes off the seat. It will start flowing straight away and increase flow very noticeably with every increase in opening%. So, in your application, you're coming up onto boost, the wastegate is closed. Boost ramps up quite quickly, because that's really what we want, and all of a sudden it is approaching target boost and the thing needs to open. So it starts opening, and ... bugger all flow. And it opens some more, and bugger all more flow. And all the while time is passing, boost is overshooting further, and then finally the WG opens to the point where the curve starts to slope upwards and it gains authority amd the overshoot is brought under control and goes away, but now the bloody thing is too open and it has to go back the other way and that's hy you get that bathtub curve in your boost plot. My position here is that the straight gate is perhaps not teh good idea it looks like. It might work fine in some cases, and it might struggle in others. Now, back to the head flow. I worry that the pissy little NA Neo inlet ports, coupled with the not-very-aggressive Neo turbo cam, mean that the inlet side is simply not matched to the slightly ported exhaust side coupled with somewhat longer duration cam. And that is not even beginning to address the possibility that the overlap/relative timing of those two mismatched cams might make that all the worse at around 4000rpm, and not be quite so bad at high rpm. I would be dropping in at least a 260 cam in the inlet, if not larger, see what happens. I'd also be thinking very hard about pulling the straight gate off, banging a normal gate on there and letting it vent to the wild, just as an experiment.
