  • Replies 42
Posted Images
Ended up heading out and running a 11.8 @ 117mph.
Humid as night out there, saw a few skylines racing too which was good, but never really had the chance to chat to anyone.
"Ignition" DVD wanted to do an article on my car but I politely advised there's no way i'm getting in front of the video camera haha
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447689
nice work. i saw your car there but never saw it run. My best for the night was a 11.194 @126mph. Didnt beat my 11.056@127mph from last time though. Thought i was goin to on my first run tonight as i got a goood launch with my best 60' time of 1.683 but missed 3rd gear and only ran 12.19 @109mph :D ohwel might head back friday if the weather is good
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447833
290kw@4... it's only running stock cams / cam gears, so need to get those upgraded, which should help :rofl: Still you've got almost 60kw@4 more than me though so i'm not getting a low 11 haha... nice work!!
Nah I didn't (I heard the burnouts were starting so started packing up). Heard it hit both left and right wall? Nasty shit :D
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447880
yeah i was lined up waiting for my last run but didnt see it happen, just heard everyone and saw everyone running. yeah from what i know after it crosed the line for an 8.6 he lost control and hit one side then across into the other.
what turbos are you running? id like to crack a 10 but i dont know if i can on the tyres im using
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447891
congrats on the time. What kind of 60' were you doing. must of been pretty average
2.3-2.4 around there.
Still trying to get the revs and clutch work down.On the night i was dialling up 3500 and slightly dumping it.Can really ride the cushion button.
Any imput would be appreciated.
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3451977
get some MT et street radials and that will be a big help.
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3452029
Tomm0 that's a very very nice GTR you have there, noticed it in the pits as I did my usual rounds.
Thanks for the compliment :)
All photos are up too guys.
http://www.cacklingpipesphotography.com/07...treetmeet_1.htm
http://www.badgerphotography.com.au/2007/S...71031/index.htm
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3454211
off the subject, did you notice much differnce when you put in the statinless steel split dump pipe? and did the flage marry up with the exaust?
yeh i really think the tires let me down.They were some old SAVAs i had in the garage.Could hardly get smoke with a second gear burnout.
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3459448
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
