Rb20 To Rb25 Conversion In R32 - Which Parts Can I Retain From My Rb20!?
err no you dont mate put my 20 into his silvia when I put my 25 in
he used a advance r32 front pipe and so did I
maybe if you doing custom mounts or something you might have to
but cefiro crossmember rb20 mounts on a 20 no problem into s13
r32 crossmember r32 mounts on to 25 into 32 no problems
rb25 vs rb20 starter motor
rb front pipe vs s13 front pipe
Edited by 1400r
hope its not the starter motor behind this.... mine isnt finished yet and i will be using the rb20 starter motor on the 25 still. Hope i dont have to change that too :D
I dont think it is..
It starts very ritch..
I have a feeling it has something to do with the fuel pump regulator or something of the sorts..
With the two Rb25 into R32 convo's i have done I noticed that the guage speed reads MORE than your acctually doing..
The only two probs I have had..
OH!.. and the pully at the end of the crank.. make sure it has as many grooves as all of the other pullies in the system..
^^ That's not what the clutch guy that built my last clutch said.
If what you're saying is the case, will that mean I need a new starter motor when I upgrade to a 25 box?
I use an rb20 starter still. I had the 2 sitting side by side when doing my rb25 swap and decided to stick with the one i knew worked. Flywheel ring gear is the same size so there's no problems there. It works with both 20 and 25 gear box. Why wouldn't it?
  • 8 months later...
Hey all, doin a 25 conversion on the R32. Im just wodering what parts from my Rb20 will swap over? I only have Rb25 block and head, no manifolds, CAS, etc etc.
Im 99% sure my exhaust manifold will swap over fine. But what else will? and What will I need to buy seperate?
Cheers in advance!
I just got my RB25DET (series 2) and I was hoping you could help me with some questions.
My Skyline is non turbo so it will be a big step with the RB25.
Now then, my first question is about the gearbox mounts, I hear they aren't the same and I will also have problems with the speedo meter. What do you know about this? Can I use the Xmember of the R33 ??
The second is about the harness, everyone that has ever swapped an engine told me that the harness is the most difficult part of the swap. Do you have the diagram of the R32 and the R33 (still can't find it for the R32) and some pointers on how this is done??
Hope to get a reply from you soon
Carlos Rudolph
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
