Hi all,
I want to bring my 33 from adelaide up to sydney, anyone know a cheap and very safe way to do so? Paint is immaculate so i dont really want to drive it up, that along with the fact that on the way i may not be able to get 98 octane fuel at some stops??
I dont really like the idea of dropping it off at a depo then loaded onto a truck then dropped off at another depo for pick up, and definitely not up for a door to door service where some dude drives the car!
Anyone ever done a transport in an enclosed truck? cost?
Does anyone recommend i drive it up? at least that way its never out of sight, but what about the petrol issue?
cheers guys, SLY
https://www.sau.com.au/forums/topic/19149-interstate-car-transport-how-to/
The only way you could have someone pick it up and drive streight to you without going through depos etc is hiring a tow truck and getting them to drive it up there, but that would be very expensive, think $50+ and hour each way. Best and cheapest way would be drive, just buy a few bottels of actane booster if there is not premium and dont do any high speed runs.
For cruising the highway, you really don't need to run 98, 95 will suffice. I ran mine on Mobil PULP from Melb to Bris (I have a Mobil card for the fuel), then filled with 98 (Ultimate) in Bris - no serious side effects yet
But check out the Shell Optimax website, it lists every servo that sells Optimax - you should be able to work out a fuel stop strategy to get you to Sydney if you really need to run 98.
I would drive it...
I did a drive where I was sure there would be no 98ron, but there ended up being a few, and whenever i saw one I filled up even if it was only $10. Only once did I have to use PULP, never had to use standard.
But if you're worried about stone chips, then maybe not...
I brought my car down Brisbane --> Canberra on a Finemores truck...cost about $300-$400 from memory. I don't think it was enclosed though.
The best protection for stone chiping is to gaffa tape the panels like leading edge of roof/bonnet/guards and front bar. You may want to do lower edge of body aswell. Tape is cheap in big rools and it goes a fairway when put on carefully
The only risk then is the h/lights and windscreen.
I have driven from adelaide to sydney, think I only had to fill up once without 98RON, and even then it was 95RON, wasn't too bad. As for stone chips, I attached some mesh cloth (kinda like shadecloth) to the front of the car, didn't look too good but it certainly did the job...... and didn't scratch the paint either. Also stopped every now and then to clean the bugs out of the grill/ducts etc.
just watch out for the rozzers on the Hay Plain, patrol car was travelling in opposite direction to me but once they saw the 'line they did a u turn, chased me and pulled me over, for no reason.
Al,
Drive it mate! I did the reverse of what you're looking at doing (Sydney - Adelaide) & it was a hoot :) If you're worried about access to 98RON then take a few 20L jerry cans of 98 in the boot. That's what I did. In the end I only needed to use 1 can for the trip. Everywhere else had 98.
As for stone chips & bugs etc.. Well you've seen my car & the front bar hasn't been touched since that drive across (other than polish). Like JR33 I stopped every so often to clean the front end of bugs & grime. This time of yr roo's aren't as much of a problem too!
The cost of a good quality full front bar respray is less than the transport costs. Plus there's always that chance the car will recieve damage during transport.
My final words of advice...... If you want something done right, do it yourself :(
Yeah, I've done Adelaide to Sydney too, its a great drive, you can sit on the speed limiter for hundreds of klm across the Hay plains (not that I did, of course). Sure, you might get stone chips, but unless youre talking show car paint job they're bound to happen sooner or later.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
