ok i don't want to start a bleed valve vs. EBC debate here so take that elsewhere please
for bleed valves: what brands are good - anyone reccommend any brands they have used? turbosmart, turboXS, any others?
i'm looking at maybe getting one but don't wanna spend much (i'm a povo), but why i'm not sure is that according to my stock boost gauge i'm runnign about 10-11 psi and i wanna go to about 12 maybe but really just want to bring boost on earlier
i also heard that with a bleed valve the trailing off of power after 6000rpm seems to go away
any advice or thoughts for those who have one already?
(yes, i know an EBC is more efective but i don't have $300+ to spend)
Waz.
Have tried both new and old Turbosmart duel boost control and was not happy.
Guy in Bundaberg makes one which works well very small too about $80....I'm seeing him on Sat.
I've now put together 3 of the Audi do it yourself boost control and they work very well...control max boost and how it comes on
around $150 to $170. Here is a link to the article
www.autospeed.com/cms/A-0670/article/html?
Edit link not working article is in issue 100 of Autospeed
Originally posted by Grim
Just buy a natural gas fitting (like the ones on BBQ gas lines) and use that to control how much air you bleed. That's what I'm running and boost comes on at 3500rpm and peaks at 12psi...and it is fully adjustable...just turn the dial.
Total cost, about $20.
do you have pictures???
I have a hi flowed turbo, on full throttle boost comes on at 2200, at 2800 i've got about 10 psi, at 3300 i've got full boost 16psi, it stays on full boost right up to 8000( 8000 hit by accident in first)
I have Turboxs dual stage - Set to 14 , spikes to 18 then comes back down - Sent to 18, spikes to 20+ (off the boost guage) then comes back down - Spikes are for about 1 second.
Prolly why my engine blew up. I'm going for EBC next -
At a reasonably sane level of boost - turboxs 'should' be OK - (10-12)
Originally posted by Sime
I've used an irrigation valve from Bunnings 3 for $4 and have the same result as Grim. No spiking either. Sounds dodgy, but seems to do the job.
yeah i have dodgy homemade one on my car .... it was like that when i bought it - does do the job but not as good as a proper one - lets just say its as open as it will go on my car :)
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
