R35 Engines?
ali-turko
 Share
  • Replies 72
if you bought the engine crated from nissan i would imagine it would have its own warranty...i think thats what a20089 was getting at...
Exactly
well call Japan after the car goes on sale and let us all know how you get on sourcing an engine :D
Putting aside the fact that EVERY single one is built by hand, and the fact that each one is built to go into an R35 GTR, which there is a backlog for... do you seriously see them being made available to the public in the next year? I'm guessing you'll be able to buy the block if you're a reputable tuning shop or Nissan affiliate, but other than that your chances are slim to none.
Now combine that with the fact that atm outside of nissan and a select handful of japanese tuning shops, no one in the world knows how to build one of these engines or tune them... and you'll start realising how much of a pipe dream it is.
Great idea in concept, but not practical. I dunno why you'd wanna burden such a state of the art engine with an old R32... for starters where would you mount the gearbox?
do you really think nissan would cover the engine for warranty if you installed it into a car it was not designed for?
i doubt it... you'd need a qualified mechanic to install it into a r35 for the warranty to be covered.
lol
but ull need to be a uptodate qualified nissan mech and installed on nissan premises
I'm not sure the OP really wanted to buy one before they are even released in Australia.....or soon afterwards.
I don't quite understand the negativity, the concept is fine. Obviously a mechanic would likely install the engine anyway.
Whether the engine fits and when you can actually purchase the engine are open for debate, NOT ridicule.
If people can fit V8's into their GTR's, then anything is possible.
what i was thinking exactly... i think the whole approach nissan was trying to get at is porka/ferrari type exclusitivity.
you don't buy these cars to have them cut up and transplanted like regular imports, they ARE the package from factory. sure minor parts here and there, most probably by nismo and most probably an arm and a leg.
Forget the GTR engine, I'd like to see the 7.0 V8 from the Z06 running a twin turbo or big single setup in a r32-r34 GT-R.
If it could be adapted to the ATESSA-ETS system, that would be a killer combination!
The concept isn't fine, it's not practical, logical, ethical, economical and a whole lot of other words ending in 'cal'. Point being read the quote in my signature...
front diff and driveshaft through the sump would be something of a nightmare (i.e- next to impossible)
unless you wanted to by the whole powertrain / drivetrain and suspension, then an engine transplant may not be feasable, although a neat idea.
what you could do is replace the engine, gearbox and other drive components of 'your' car with those of the gtr and shorten the propshafts and 4wd transfer shaft lengths to match your wheelbase.
although it does make things difficult! with the new rear mounted gearbox.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
