R35 Gtr - Dual Exhaust Myth & Spotted Cool Features
Hey,
Just remember someone saying how it would be expensive to modify the GTR and one of the reasons was it had dual exhausts so would cost twice as much. Basically what im getting at is the illusion that it comes with dual exhausts like a 300zx, looking at the below pic you can see that it goes to a single pipe halfway along and splits again at a T piece near the rear, so its not a true dual exhaust.
This surprised me as I thought they would go a full performance dual exhaust being the performance/supercar car it was built to be, but instead it looks its small and restrictive and not what you'd expect to see on a turbo'd car. Its obviously good / flows enough though for the power it puts out. Anyone else have these thoughts?
Cheers!
Gagz
PS..Does anyone actually know where it states what type of exhaust it is....diameter (2.5"??), material (titanium??), press bent or mandrel...etc??
Edited by R31 Gagz
when its not mandrel bent there are areas inside the pipe where the air doesn't flow smoothly, and can cause restriction.
afaik the exhaust isn't titanium, which a lot of people have commented on... and are expecting aftermarket companies to come out with full titanium exhausts to drop the weight of the GT-R a little.
Didn't notice the 2 to 1 to 2 layout of the exhaust... maybe we might see straight twin pipe exhaust systems pretty soon... or maybe the underbody layout doesn't allow for seperate pipes? Nissan did say they put a lot of effort into making sure the car was highly aerodynamic.
Thinking something like this:
Keep in mind Nissan would have done its best to cut down on emissions to meet Japan and the US's laws.
I thought it was mentioned somewhere that on the options list will be a titanium exhaust, reducing the weight by 10-15kg.
Most likely will be standard on the "V-spec" and up...
i think this was on the edmunds site
man, soooo many cool things still to come from this car. JGTC, V-spec and more hardcore versions, Nismo versions, tuning house versions (Mines), all the aftermarket goodies... exciting times :P
EDIT: tread pattern on those tyres are really interesting...
looks like the exhaust is the easiest way to gain another 30-40kw? :P
I would bet my money on a "chip" or ECU reprograming to be most cost-effective performance gain for the new GTR. Look at two other modern twin turbo 6 engines; 997 Turbo gets an extra 50-55kw from a software and a Chiptorque piggyback can give a BMW 335i an extra 35kw at the wheels!
Whats the secret? You know it. BOOST, FUEL and TIMING. Changing exhaust on these cars do help but not as much as a software.
Remember this GTR was built without "the gentlemens agreement" in mind. I would expect the factory exhaust to be quite free flowing but relatively muted in sound.
353kw isnt much power at all.... looks like the exhaust is the easiest way to gain another 30-40kw? :down:
I wouldn't say its not much power at all except in comparison to some very high power cars. I guess that system is good enough for current power but when you want to get serious power, an exhaust upgrade is definitely on the mod shopping list :) If I ever had enough money to get an R35 I would probably upgrade it anyway and maybe the air intakes depending on how good the stock ones are just so it could breathe easier, free up a few kws.
Cheers!
Gagz
this one is nose heavy anyway- the balance is reported to be 58:42
That has to be a typo. Even the average FWD Avagnary has a better weight distriution than that.
I'm thinking more like 48:52. Surely the Nissan engineers couldn't get the weight distribution so horribly wrong. It would handle worse than a 265 Centura.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
