My mum has been busting my balls lately cause i told her about me just purchasing a hks super dragger exhuast with 2.5inch piping but its 2nd hand
she keeps nagging me to get her friend who owns a custom exhaust centre to make me one at pretty much nothing.....if i went with the custom made exhaust will i still get the increase in power made compared to a hks super dragger???? i dont think i would..so im better off with the hks yea???
bollocks. get the custom made one. if the guys making the exhaust have half a clue they should be able to craft one that gives you enough flow but still keeps the noise down.
i have no idea - i have heard that they are the shiz-nit
but others say not
i say go custom, cause the guys there have built it, and know whats in it, and if anything breaks or goes funny, they no what to fix.....
Isnt the HKS 3"? Cos then its too big..
Either way its better to go custom..
See if you can go balls out and get it made out of titanium!!!
If its possible.. I'd say screw HKS, get it custom, 2.5" titanium..
..yum yum..
haha cris
titanium = big big big bickies
the superdragger comes in 2.5, 3, 3.5 and i think even 4 inches daimeter...
Fully aware of this..
but..
:P
Even if it ends up costing the same price as a normal zorst.. or a little more.. your getting the same performance, saving ~20kg for a full zorst.. and the the *BLING* *BLING* factor
yea true how i know whats in it how it been built and guys will know how to fix if anything goes wrong
but only problem i have is finding a cannon muffler...i dont want a droaning xforce muffler i would love a apexi n1 to go on the end but yeah hard to come by with 2.5 inlet :P
if i can find a good muffler loud but not too droaning then ill go custom all the way.
actually cara it would be interesting to see a b4 and after dyno graph if you changed from the 3 inch to a 2.5 inch
one would imagine the mid range would beef up a bit and the top end would drop a fraction
3" is a bit big for an N/A i reckon... you won't get enough back pressure.... it'll kill your low end torque. comparing kw's before and after is pretty stupid when it comes to an exhaust, especially on an N/A. you need to focus more on the power delivery thru the rev range before and after. a good exhaust will boost your torque and power throughout the rev range, not just peak power.
not to mention low to mid would be ALOT more responsive.
Im with funkymonkey..
NA engines are about responce..
I laught when people say "I want 300KW"..
Focus your NA on responce and trorque with a beefy power band..
2.5" is good for an NA..
3" is a bit big for an N/A i reckon... you won't get enough back pressure volumetric vacuum/flow.... it'll kill your low end torque. comparing kw's before and after is pretty stupid when it comes to an exhaust, especially on an N/A. you need to focus more on the power delivery thru the rev range before and after. a good exhaust will boost your torque and power throughout the rev range, not just peak power.
exactly...
but for cara's purposes on the dyno, 3" is good i suppose.
my stance on custom vs. off the shelf (jap spec), will always lean towards the off the shelf item. NA RB's are notorious for their characteristic twin cam metalic ring, and it can be a headache to deal with if not done right.
i've never seen custom exhaust items as a positive, more as a negative - hks/fujitsubo, etc. don't invest big dollars into providing an item that has withstood the test of time as a bad product. things like tuned length, dB, emissions (fujitsubo legalis r?), flow, etc. are all factors that time has proven. i would very much prefer a proven product than one put together by the local guy who normally puts together 8 pots.
however if other factors such as cash is involved, then by all means prioritize your criteria accordingly.
back when I had an R32 GTS I had a fujitsubo legalis R exhaust and a legalis super Ex extractor system. was 2.5" and it droned like a bitch... plus the full stainless system added this tinny noise that made the car sound wierd when it revved.
ended up ditching the legalis R (sold it for a mint too to some brand name hugging buyer on ebay) and getting Tuffy's mufflers in sydney to make me up a custom exhaust. Again done in stainless steel, but this time with a proper resonator to get rid of that metallic noise from the exhaust, and cut down the drone. Still got a little metallic noise from the extractors, but it wasn't that bad. Since they were both 2.5" I didn't really see any change in performance or response, but the change in noise was amazing.
the problem with the fujitsubo, and I suspect with other japanese off the shelf items is that they are designed for turbo AND non turbo applications, not designed for use with an australian cat converter and don't have to meet the same noise emissions as we do. Getting a custom one made up will sort that all out for you.
the extractors and the exhaust:
i got a custom in mine, everyone said 2.25" and the exhaust guy so i got 2.25.. now everyones saying 2.5?
heres wat it sounds like with a magnaflow muffler and resonator :
http://youtube.com/watch?v=uRDVFAh0F24
hey leigh niceeee sound you have there
want someyhing similar bit more roary though but probably have the right sound with 2.5
ill have my mind made up once i speak to my mums friend the exhaust guy..
anyone heard of his company...called Pro X or something??
Yeah people were telling me to get a 2.25" for any real benefits for N/A engines. 2.5" I guess is acceptable but probably would be better on cars with small turbos/ lower boost. 3" for bigger turbos and higher boost. I think anything larger than 2.5" on an N/A would = higher than 90db defect.
I could be wrong though.
it's a compromise on an NA.
2.25 is what i would recommend for a car that's being driven around town, to the shops, to uni, work, etc.
however if you regularly see high rpm applications, i.e. track work - then 2.50" would be the ideal choice.
it's quite dependent on your application, none of this dyno rubbish in regards to kilowatts. everyone knows that a dyno reads maximum power at whatever rpm (more often than not, high rpm/near redline)
by choosing the correct exhaust diameter you are effectively putting your 'power/response/gigawatt/driveability' band in the range where you most frequently use it. there's no point in having a 11ty" exhaust, when you're only using 2000 - 4000 rpm daily,
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
