hey ummmm
question...
how many people can honestly say that their MUM of all people their MUM NAGS THEM
...to get a 2.5" custom built exhaust system? OVER A HKS
mym nags me to NOT get an exhaust system and focus on other things?
this is highly irresponsible lol
i stand partly corrected then.
those tuned length headers look sweet, if they didn't cost an arm and a leg i would have gotten them.
Ive got them on my car, thoguh they've gone a goldy colour, damn they sound good, 6-3-1 (the 3-1 is 2x2" to 1x3") on a 3 " system on the high comp RB30DE god it sounds angry
Well mum rather me get a custom exhaust done for pretty much nothing ratrher than me blowing 500+ on a 2nd hand hks
yeah mine went gold as well... must be the chrome reacting when heated.
i gained 16.9 kW from my 3" exhaust, and when i put the extractors on, i gained responsiveness plus plus. if you know what i mean.
that's still peak power cara...
did you manage to get dyno graphs?
and you have to keep in mind you have the 25DE NEO, mods will respond differently to the RB25DE
yeah i guess thats true, maybe the neo engine do better with 3" exhaust compared to the normal RB25DE.
before power with stock exhaust was 101kW, then went up to 118kW from memory, and yeah i have all my dyno graphs :)
i guess in the end i would buy new cause at least you can get some sort of warranty on it, while buying 2nd hand means you probably dont get anything of the sort :(
my mum nearly had a heart attack when i told her i paid nearly 1000 buck a roonies fro my exhaust..........she got over it LOL
before power with stock exhaust was 101kW, then went up to 118kW from memory, and yeah i have all my dyno graphs :(
i'm more interested in the area under the curve, not how high curve reaches :)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
