yea was a little tight loosened it no diff, also tried removing the spring washer no diff, only thing i can see it being is that the white little bit on the end is really tight so im hoping it will wear in... and by the way, the white thing on the end of the shiter is $11.50 from nissan not $4 like some ppl were saying....
Edited by skiwhine
i put a ebay shifter in too. had to make up a spacer so it didnt clamp down on the pivot ball to much making it stick, also welded in top half of original shifter to stop noise coming up. have got a basic drawing of what i done but wont let me put it on here. if interested pm me!
Edited by Pal
what washer?
n recap, have driven it a bit and it seems to have worn in when slappin 3rd i jus make sure i shift in a diagnal fashon to be safe :rofl:
short shifter rocks 2 btw, stand shifter i wouldnt use on a $50 go-kart
  • 3 months later...
Old post revived i know but i put one of these shifters in an found the square clamp to be to tight so i used the new bush which tucks in over the ball of the shifter an the original two C clips that were on the standard shifter instead of the metal bracket an seems to work a treat. Not to tight but not to loose either an much shorter throw. Only thing is now i can hear the whinge of the gearbox as the syncros are under more load. I dont abuse the hell out of my gearbox so how long roughly will it last??? Thinking of even going back to the original shifter just to quieten it down...
have driven a 33gtst that had a short shifter - made the same noise. i asked about it - was my neighbours dads car - and he said it was on the car when he bought it 8,000km ago. no dramas. just noisy. Didnt know what it was making the noise tho!
you don't get a rubber bush on short shifters so all the noise from the g/box get transfered straight up the shifter. i cut my stock shifter below the rubber bush, done the same place on the short shifter and welded the stock shifter onto the short shifter bottom, walla, no more noise and feels even better
(make sure you get someone who can weld to do it,i got my mate who's a pressure welder to do mine)
That is such a good idea. I hate the sound of the gearbox through the shifter, also the heat transfers through it making the gearknob and gearstick surround going hot as.
i had trouble with the lil plastic bushing being too small, so i bought the metal one from cusco and i will see how it goes, i got a real leather nismo (fismo) boot also with red stitching to match my car
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
