Hey guys, my 33 series 2 come fitting with 4 week old G4 street spec coilovers. http://www.justjap.com/g4streetinfo.htm
awesome for the highway, just wondering how i can make these things more bearable to drive on shitty north brisbane roads. So far ive just been adjusting the turning knob things on the top of the shocks (damper and rebound apparently). when i set them to hard they are really bad and stiff and you feel everything, then i set them to soft, they are just really bouncy, and its a bitch to drive. somewhere in between is the best. Ive been driving around for ages with the backseat out trying out combinations for a while now. The only time its good is when i have fat people in the backseat.
Before i take my wheels off... reading the specs above is there anything else i would be able to adjust? Or any other suggestions for making the ride smoother?
https://www.sau.com.au/forums/topic/191623-adjusting-g4-coilovers/
they are 12 n 9 front n rear respectively....too hard for the pot hole patched up roads of australia.lol....good for nice flat rds like the highway. the rebound/dampner settings arnt that good. Use on daily car can get bad! thats why i sold mine, after a yrs use and 2 replacements of shocks cause of leaks.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
