lol
and since i have pwnage on page 6
Here's the list.... again
Marsss
Smasha
SECURITY
Primordial
d00dz
phillb
carmasupra
Wink
HOT_R33
lingeringsoul
RSTME
msnismo
DRD-00F
A NewTattoo :rofl:
benm
wraith_skyline
Miss Turbo
gr34tt
burnsie
Sinful
Giffo
Assasin
sewid
ONN20S
boki82
D_I_F
Smoky
R338OY
r32woohoo
LANFOH
mikey1717
SAM916
LOOF
Jago
Tinks
intune
GoldZilla
Cassbo
Blitz
Abo Bob
MZTRBO
R`Style
phillb
bigbaz
Sl!m
  • Replies 367
Posted Images
hopefully it wont rain tomorrow
i been waiting for this cruze for 3 weeks ;)
They reckon a couple of showers, but should be fine.. =)
Marsss, add the other people from my list too mate. They have all confirmed 100%.
I'll pop along to say g'day, don't know if I'll make it out to Newport as I'll have been awake for close to 20hrs!
(At least the fat ho will make R33's look like anorexics :) hehe)
This carpark's the one which you turn left into the big DJ's down at the Nerindah St lights isn't it?
Correct
PS.. for the newbies, open up www.maps.google.com and plug the following into the search field to find the entrance to Chatswood Chase
-33.7951,151.186852
keep in mind that there's a few other carparks around and that it may get a bit confuzzling. but when you're travelling along the Pacific Highway (southerly direction), turn left into Albert Street, follow that for a bit and then turn left again into Neridah St. When you reach the lights at the end of Neridah you'll see a ramp in front of you... go down that ramp!!
omg gawd, pizza cruise! no wai!
nah this isn't a pizza cruise, I'm just recruiting suckers for the defect station thats going to be set up in teh carpark. I'm working with the local cops, I get $5 a defect, so I'd be few hundred dollars richer by the end of the night.
Don't be shy now, come one come all!!! and make me rich.
pfft...
just 'cos your car has nothing to defect, James :)
Guest
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
