Just a quick note for everyone to be on their best behaviour tonight. Obviously it's been mentioned already but these cruises have been going on since before I even had my skyline with no trouble and due to the sheer size of this one all eyes will be on us tonight.
Be good ambassadors and prove that there is a difference between a hoon and an enthusiast.
Have a good one everybody.
  • Replies 367
Posted Images
good...someone has to watch what you get up to....
As if I need watching Marsss!!! I'm a very well behaved person.. Lets just hope (For everyones sake) we don't crack out the grog too soon at work. :wave:
Marsss im not even on the list i told you ages ago i was coming, it may have been on the wrong thread and may have been a different forum completely, but anyway i'll be there in ZXT45Y who is a little banged up right now from a celica pulling out in front of her but she will be alright
To put it simply, increased police presence.
Just another reason why I really hope that everyone attending tonight can control themselves and not attract unwanted attention.
man..i had no idea it was that bad, it's been a year since I lived up north.
i beleive my car is being shoe horned into msnismo's spot because her car won't be making it. Transfer of cruise rego you know how it works.
Yep... killed both cars in less than a week.... il be shotgunning it.... oh waits... that means I can drink!!!
I'll see you at Anna's Greg, will be giving you guys a hand :)
Yessum.... getting the motivation to go to teh garage now....
Sweet :D . I'll bring the beer
Awesome... il drink it!
Guest
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
