  • Replies 367
Posted Images
How about this... if you're worried that you might get defected for whatever reason... just go straight to the pizza place. On that point though... you may consider making your car legal in every way if you drive it everywhere.
just sayin'
Good point mars, but it's a small price to pay if it means the cruise is not to be hassled by the cops from the very start isnt it?
Just let them know there will be 'a group' of cars there.. They are much more likely not to call the cops if they at least have some clue that there is something going on rather than shitting themselves and panicking when 100 noisy cars randomly turn up in their car park!
tbh, I reckon if you call and say "we have 50 skylines coming to meet here on friday" they will most likely say: "we don't give you permission to use our carpark as a meeting place" if they say that, and you guys turn up anyway they would quite possibly have cause to charge with trespass. it's a tough situation. I guess if you call and ask them, and they say no then at least you will know in advance and can organise another spot.
An alternative is to meet on the ground floor of the Westfields carpark (the big, ex council carpark?). In the far corner, as far opposite the Victor St entrance as possible.
The ground floor is relatively low car friendly, and in that corner there are fewer people parking as its really far away from shops. Being away from the exit, you generally won't be interfering with customers coming and going, so its less of a hassle for management.
Also, there's an open air carpark between Claude and Archer St across from the Westfields carpark. I don't know if it'll fit 50 cars, but it will fit quite a few. Its across the road from the police station though.
Ok people I have just spoken to Andrew at Chatswood Chase and everything is ok with us meeting there. To make sure, i ALSO spoke to the people that do the security there and they're aware that we'll be "taking over" the carpark on friday night. Once again, when you come in please do it in an orderly fashion as we DO NOT want any problems with ANYONE
Thank you.
Thank you.
That's awesome. Thanks Mars..
Wow.. proper organisation and stuff.
I'll call Lucky and Peps and let them know we'll be there as well
Thank you.
nice work mate :thumbsup: I'm surprised they are cool with it. but that is a great result. it means the likelyhood of hassles has just reduced to practically nothing. providing all attendees behave themselves of course...
I will remind everyone that trying to set of your BOVS, or gate, or generally just trying to fang in the carpark is not considered cool by anyone. yes we all know how loud and manly your car sounds in an underground carpark, but keep the speed below 10kmh and the rpm below 2500 and everyone is a winner. :thumbsup:
It's either Baron or Adam.. They do it to me all the time :thumbsup:
lol, it was adam. I think maybe he doesn't remember about how offical sau is and was just trying to raise the level on spelling on the forum. but we all know this really is offical. :thumbsup: no doubt.
Guest
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
