Yeah mine has it to. Allthough when we replaced the windscreen just put a standard one in there. Couldnt justify the price difference for the amount of time im likely to use it.
Didnt know it did the mirrors though, might have to try it.
bit of a hijack
but what does the button do which is located behind the steering wheel on the dash which looks like
.I--o--I.
.....l......
.....S.....
.....l......
.I--o--I.
(ignore .'s)
sorry for the crude font sketch
and what is the purpose for the snow switch on the console
it is an rs4 - so i guess it just shifts to 2nd early to stop spinning yeah?
Edited by 910trx
put everyones mind at ease, when i pick my car up.
its got the owners manual (english) i will just copy down what it says in there then , mystery solved !
RBPOWA have u got a scanner. can u scan the manual and put it all up for us. Will take a while but will help alot.
ok got the book back. word for word on this switch from my manual
WIPER DE-ICE SWITCH (grade)
The ignition must be ON. It is designed to heat the lower part of the windscreen trough embedded heating wires to help melt any ice that has formed around the wipers.
Press the lower part of the switch and the system will turn on for 15 minutes, then automatically turn off. If your wish to turn the de-icer off manual simply press the lower part of the switch.
this part is from the adivce section .....
' in vehicles with door mirrors, the door mirror heaters will also operate when the rear defogger switch is pressed.'
I'm going to have to check if my aussie mirrors will de-fog , I know that windscreen de-icer works.
But the real question is:
What the heck does the 'Light Reduce' switch do? And it is messed with at compliance? I'll be damned if I can detect anything changing on my car with it 'on', so I leave it 'off'.
I've heard plenty of 'theories', but no definitive answer. Further to that, if the feature is useful, then I'd like to know how it's been disabled at compliance. I have found no power on any of the wires going to the switch, nor any fuses that seems to relate to it.
If you do not have xenons it could be this:
From what I can make out, it increases or reduces the intensity of your headlights depending on what your are doing eg. stopped at lights - low intensity, driving at high speed - high intensity, it may even lower the intensity when you are passing cars, I'm yet to work it out. There's something you can try on the weekend.
P.S If you have "aussie compliance" mirrors they will not defog.
Cheers 'Stagea' :P
That sounds about right, but I'll be damned if I can actually notice any change (had the car for 4+ years!). I'll turn it back on & have another look, but I expect that compliance has interfered with it (I suspect that such a feature wouldn't be ADR compliant).
Suspected as much about the mirrors - the lack of convex is a real bugger. One day I'll get some JDM mirrors to fix the issue...
Edited by BensDR30
have you changed the batteries? do the lights come on or does it beep when you push them?
there is a switch, down near your right leg under the dash on the right
That was my first thought, no I haven't yet. The light comes on on the remote starter, no beep tho. Should probly change the batteries first and then start looking elsewhere.
CHeers
Hey there
The switch that you are talking sounds like it could be to heat up your wipers, you can tell by having a close look at your windscreen, if it does have the heating elements in the glass they are orange in colour and usually have three long strips where your wipers sit in the off mode. If the heating elements are in the black part of the glass (ceramic) it will be very hard to see but you should see them.
If you do happen to have the heated windscreen make sure you have glass cover on you insurance, if you think the price of a normal windscreen for a stagea is expensive wait till you find out how much a heated one is!!!!
Damn straight, thats why I just went with a standard windscreen. I mean when am I going to use it in QLD. But at least I still get to defrost my mirrors :P
was the car fitted with an immobiliser or alarm on compliance or after?
Far as I know there's no immobiliser, the bloke I bought it off hadn't fitted anything to it. And he got it from an importer, and the import ad says nothing about an immobiliser. Or an alarm for that matter.
As you may have already guessed I am, what I believe is classified as, a noob! So here's a pick of what I've got.
This add was made in January last year, that's when he bought it. And I got it for $9900 :P
Thanks for your help
Did the car with any other remotes?
Try pushing the start button twice with a 1 second gap in between.
Did you find the master switch in the right hand drivers footwell?
Experimentation it the key (no pun intended)
You'll need to use your powers of deduction to work it out.
What state are you in?
No other remotes, only other remote is central locking on the key.
I did try pushing the start button several times, with various time lapses. But I will try again.
There is also a button in the middle, I'm not sure what it's supposed to do, when I push it the red light above it flashes intermitantly for a few seconds. If I push the start button whilst the light is flashing the light stays on without flashing for a few seconds.
I deduce that perhaps the middle switch is to arm the remote start. Would this be plausible?
However when I tried this it still did not work.
I also tried it with the car unlocked, and siting inside. Nada.
I did find the master switch, and I tried the remote start with it in both positions (up and down).
And still nothing.
I will try all these things again, just to double check.
But failing that, should I just give up?..........No there must be a way!
Cheers
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
