Welcome blade. I dont know if its changed but my HID on my V35 S2 2005 were disconnected on compliance (2007) & I had to refit them. It had something to do with matching the right Aust standard which wasn't available at that time- I would think it should be ok now. I cant be sure for the Stagea but should be very similar. On the V35 it wasn't that hard to put back- make sure the compliers give you the wiring and the HID fitting or get them to fit after its registered - its perfectly legal to have them- just the compliance
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742088
Yeah it seems that this is still the case. Sadly my compliars were very 2nd rate, I can't get answers nor a reply from them.. So looks like I'll have to spend some hard earned soon and rectify it.. Will have to start looking into getting some genuine replacements, car hopefully is delivered today, so I'll hold off until I have a list on what I need.. Can only assume ballast & globes..
Many thanks
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742705
The reason the hid's are removed is because they don't meet the ADR standards (toss, toss) for being self levelling and having water spray jets. Silly as it sounds, that is the reason because in Australia we know more than the rest of the world.
You should ask the compliance mob to give you the globes and ballasts removed from your car if they did indeed totally remove them.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742746
Blade511- Your compliers should NOT keep anything from your car - ITS YOURS. You should demand and get it back- its nothing short of theft!. I have no idea why anyone would touch ballast other than to steal it (which is usually a big job to remove anyway). Usually the wiring is disconnected from behind the headlights & somewhere in the engine bay/wheel arch, the they just modify a bracket / wire for standard globes!.Noone should be touching your ballasts!. They are about 750new (if you can find one). I know because I had to change one ($220gen 2nd hand one). I was lucky I had a friend comply it and the compliers talked him /me through every detail, they kindly bundled the wiring and bulbs in the Glove box. I was very lucky my car still has the jap warranty card for the impul chip and fujitsubu exhaust, spare key + vallet key. If anyone took anything from my car They would be very very sorry..!. You know the car has it- go there & get it!
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745136
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745139
Could not agree more.. I've been on one hell of a back and forth and am starting to get results.. But they are painful and am at the point where enough is enough.. Put simply I don't want to deal with them any further. And would be happy to send them a bill just to stir.. However, you and I both know that I'll be wasting my time when it gets down to the nuts and bolts of it.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745461
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745462
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745464
  • 4 months later...
  • 2 months later...
Hi guys,
I'm looking to buy a 2008 nissan skyline 370gt v36. It's an import with navigation system and stuff in Japanese. That's fine, but since I have never owned an import car before, I would like to know if spares are readily available in WA? Or in the eastern states? I'm getting an inspection report done as well. Anything I should keep in mind when I go have a second look and drive? Your advice and help will be greatly appreciated.
Thanks.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7809295
  • 1 year later...
Here are some pictures of my latest buy, a 2005 350GT auto.
Driving buy the local car yard & spotted it on the lot for $10990NZD. Had a look on the web-site & found out it only had traveled under 50,000k so I decided to go have a look. Took it for a spin, loved it, so I bought it!
Runs on 17s, has black cloth interior, factory tinted windows & no wind deflectors over the doors (which spoils the look).
I got a gadget that plugs into the cig lighter socket to play music from my phone through the factory head unit.
The pictures ain't the best but had to take them between heavy rain showers from my phone.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7881710
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
