Welcome blade. I dont know if its changed but my HID on my V35 S2 2005 were disconnected on compliance (2007) & I had to refit them. It had something to do with matching the right Aust standard which wasn't available at that time- I would think it should be ok now. I cant be sure for the Stagea but should be very similar. On the V35 it wasn't that hard to put back- make sure the compliers give you the wiring and the HID fitting or get them to fit after its registered - its perfectly legal to have them- just the compliance
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742088
Yeah it seems that this is still the case. Sadly my compliars were very 2nd rate, I can't get answers nor a reply from them.. So looks like I'll have to spend some hard earned soon and rectify it.. Will have to start looking into getting some genuine replacements, car hopefully is delivered today, so I'll hold off until I have a list on what I need.. Can only assume ballast & globes..
Many thanks
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742705
The reason the hid's are removed is because they don't meet the ADR standards (toss, toss) for being self levelling and having water spray jets. Silly as it sounds, that is the reason because in Australia we know more than the rest of the world.
You should ask the compliance mob to give you the globes and ballasts removed from your car if they did indeed totally remove them.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742746
Blade511- Your compliers should NOT keep anything from your car - ITS YOURS. You should demand and get it back- its nothing short of theft!. I have no idea why anyone would touch ballast other than to steal it (which is usually a big job to remove anyway). Usually the wiring is disconnected from behind the headlights & somewhere in the engine bay/wheel arch, the they just modify a bracket / wire for standard globes!.Noone should be touching your ballasts!. They are about 750new (if you can find one). I know because I had to change one ($220gen 2nd hand one). I was lucky I had a friend comply it and the compliers talked him /me through every detail, they kindly bundled the wiring and bulbs in the Glove box. I was very lucky my car still has the jap warranty card for the impul chip and fujitsubu exhaust, spare key + vallet key. If anyone took anything from my car They would be very very sorry..!. You know the car has it- go there & get it!
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745136
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745139
Could not agree more.. I've been on one hell of a back and forth and am starting to get results.. But they are painful and am at the point where enough is enough.. Put simply I don't want to deal with them any further. And would be happy to send them a bill just to stir.. However, you and I both know that I'll be wasting my time when it gets down to the nuts and bolts of it.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745461
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745462
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745464
  • 4 months later...
  • 2 months later...
Hi guys,
I'm looking to buy a 2008 nissan skyline 370gt v36. It's an import with navigation system and stuff in Japanese. That's fine, but since I have never owned an import car before, I would like to know if spares are readily available in WA? Or in the eastern states? I'm getting an inspection report done as well. Anything I should keep in mind when I go have a second look and drive? Your advice and help will be greatly appreciated.
Thanks.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7809295
  • 1 year later...
Here are some pictures of my latest buy, a 2005 350GT auto.
Driving buy the local car yard & spotted it on the lot for $10990NZD. Had a look on the web-site & found out it only had traveled under 50,000k so I decided to go have a look. Took it for a spin, loved it, so I bought it!
Runs on 17s, has black cloth interior, factory tinted windows & no wind deflectors over the doors (which spoils the look).
I got a gadget that plugs into the cig lighter socket to play music from my phone through the factory head unit.
The pictures ain't the best but had to take them between heavy rain showers from my phone.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7881710
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
