Welcome blade. I dont know if its changed but my HID on my V35 S2 2005 were disconnected on compliance (2007) & I had to refit them. It had something to do with matching the right Aust standard which wasn't available at that time- I would think it should be ok now. I cant be sure for the Stagea but should be very similar. On the V35 it wasn't that hard to put back- make sure the compliers give you the wiring and the HID fitting or get them to fit after its registered - its perfectly legal to have them- just the compliance
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742088
Yeah it seems that this is still the case. Sadly my compliars were very 2nd rate, I can't get answers nor a reply from them.. So looks like I'll have to spend some hard earned soon and rectify it.. Will have to start looking into getting some genuine replacements, car hopefully is delivered today, so I'll hold off until I have a list on what I need.. Can only assume ballast & globes..
Many thanks
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742705
The reason the hid's are removed is because they don't meet the ADR standards (toss, toss) for being self levelling and having water spray jets. Silly as it sounds, that is the reason because in Australia we know more than the rest of the world.
You should ask the compliance mob to give you the globes and ballasts removed from your car if they did indeed totally remove them.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742746
Blade511- Your compliers should NOT keep anything from your car - ITS YOURS. You should demand and get it back- its nothing short of theft!. I have no idea why anyone would touch ballast other than to steal it (which is usually a big job to remove anyway). Usually the wiring is disconnected from behind the headlights & somewhere in the engine bay/wheel arch, the they just modify a bracket / wire for standard globes!.Noone should be touching your ballasts!. They are about 750new (if you can find one). I know because I had to change one ($220gen 2nd hand one). I was lucky I had a friend comply it and the compliers talked him /me through every detail, they kindly bundled the wiring and bulbs in the Glove box. I was very lucky my car still has the jap warranty card for the impul chip and fujitsubu exhaust, spare key + vallet key. If anyone took anything from my car They would be very very sorry..!. You know the car has it- go there & get it!
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745136
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745139
Could not agree more.. I've been on one hell of a back and forth and am starting to get results.. But they are painful and am at the point where enough is enough.. Put simply I don't want to deal with them any further. And would be happy to send them a bill just to stir.. However, you and I both know that I'll be wasting my time when it gets down to the nuts and bolts of it.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745461
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745462
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745464
  • 4 months later...
  • 2 months later...
Hi guys,
I'm looking to buy a 2008 nissan skyline 370gt v36. It's an import with navigation system and stuff in Japanese. That's fine, but since I have never owned an import car before, I would like to know if spares are readily available in WA? Or in the eastern states? I'm getting an inspection report done as well. Anything I should keep in mind when I go have a second look and drive? Your advice and help will be greatly appreciated.
Thanks.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7809295
  • 1 year later...
Here are some pictures of my latest buy, a 2005 350GT auto.
Driving buy the local car yard & spotted it on the lot for $10990NZD. Had a look on the web-site & found out it only had traveled under 50,000k so I decided to go have a look. Took it for a spin, loved it, so I bought it!
Runs on 17s, has black cloth interior, factory tinted windows & no wind deflectors over the doors (which spoils the look).
I got a gadget that plugs into the cig lighter socket to play music from my phone through the factory head unit.
The pictures ain't the best but had to take them between heavy rain showers from my phone.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7881710
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
