There is no VQ35DD engine, the 3.5L engine is not direct injected, so it is a VQ35DE.
The oil consumption issues you read about are likely realted to the 'rev-up' version of the VQ35DE fitted to the 05+ Infiniti G35. This engine was never used in the skyline.
OK, thanks for clearing that up for me.
I assumed the VQ35 in V35 was DD, I see that's not right at all now.
You have put my mind at ease.
https://www.sau.com.au/forums/topic/191705-newbies/page/38/#findComment-6682531
On topic of the oil consumption issues.. my car has used almost 1.5L of oil in around 7,000km/6 months. Definitely doesn't seem normal to me, but i keep getting different dipstick readings it's very annoying and it's such in a stupid location!
I find I need to let the car sit for about 10 minutes after stopping before checking the oil.
It seems some oil in the head returns to the sump via the dip stick. Making it impossible to get an accurate reading until it has finished draining.
Same on the VQ35DE in the maxima.
https://www.sau.com.au/forums/topic/191705-newbies/page/38/#findComment-6682799
Noob question, are V35 coupe front struts, shocks and springs interchangable /direct fitment for to V35 sedan?
Interchangeable. Yes. But the coupe springs are slightly lower than the sedan springs (about 12mm or 1/2 inch)
Thanks mate,
What about 350Z front struts, shocks and springs?
I have read that they will swap over to V35 coupe, but are 1" lower?...... So therefore are 1 1/2" lower on sedan?
Can any one confirm this for me please?
Also, would anyone know is V35 sedan and coupe front seat interchangeable? Do they share the same base frame mounting points
Al
Edited by FUTO_GT
https://www.sau.com.au/forums/topic/191705-newbies/page/38/#findComment-6684092
350z springs will give a 1in drop on a sedan or a 1/2in drop on a coupe.
Not sure about the seats, but I don't think they are a simple swap.
So, let me get this straight, are you saying that the 350Z struts don't bolt up to V35 knuckles and struts towers?
But that the springs out of the 350Z struts and rears fit V35 and give the lower ride height when installed?
https://www.sau.com.au/forums/topic/191705-newbies/page/38/#findComment-6684650
350z struts and springs are a direct bolt on to coupe and sedan Vs. it will lower the sedan by 1" and the coupe by about 1/2"
https://www.sau.com.au/forums/topic/191705-newbies/page/38/#findComment-6684689
^^ this.. everything fits, the V35 coupe, sedan and 350z all use the same suspension setup.. the only difference is the ride height with the different springs. The 300gt and 250gt may have had lighter duty shocks too if they had lower spring rates.. not too sure on that one though.. n15m0 can probably anwer that too..
https://www.sau.com.au/forums/topic/191705-newbies/page/38/#findComment-6684857
  • 3 weeks later...
Hey all. Just thought i would do my introduction since i have been lurking around the forum for a little while.
My name is Mathew and i am from Adelaide.
Here is my 03 350gt that i have owned for a month.
I love it! Best car i have had for sure, just an absolute pleasure to drive with the 6spd.
Im keen to know more about the car and would like to meet up with felow enthusiests one day.
All i have done to it so far is remove the "skyline" badging, boot lip spoiler and swap "S" plates for premium squares.
Plans are wheels, exhaust and bits n pieces to make it a little more agile.
Maybe an air induction kit of some sort too.
Cheers
Edited by Triggs
https://www.sau.com.au/forums/topic/191705-newbies/page/38/#findComment-6712781
Hi guys my name is Mark and I just joined yesterday. I bought my 03 350gt 2 days ago and I couldn't stop browsing around this forum even when I was at work. Anyway here is the pic of my car.
http://imageshack.us/photo/my-images/837/20130118193216.jpg/
http://imageshack.us/photo/my-images/266/20130117130002.jpg/
https://www.sau.com.au/forums/topic/191705-newbies/page/38/#findComment-6713131
Thanks mate. I couldn't stop looking at v35's since I got mine. First thing I did when I got it home is cleaned the whole car and fixed the seat. The previous owner thought that its broken but once I got home I disconnected the battery and took the seat out, disconnected the motor and manually winded the seat and moved it forward a bit. Reconnected the wiring and voila its all working. The only issue is if you move the seat too far back, it gets stuck again. I need to clean the rails properly, ill do that when I get time off work.
https://www.sau.com.au/forums/topic/191705-newbies/page/38/#findComment-6713140
hi all
im new to this forum. bought a v35 coupe about two months ago after totalling my rex. i bought sone lenso D1r's last week with folling specs - 18 inch 9 +15 and 10 +22. havent bought any tyres yet. was wondering what will be the best tyre size for my wheels which doesnt require too much work ie; guard roll, camber ect. im on stock suspension at the moment and plan to drop the car abut an 1 - 1.5 inches
thanks
https://www.sau.com.au/forums/topic/191705-newbies/page/38/#findComment-6715669
    • I should. But it already uses too much fuel for a daily. You might note my recco for engine chnages are almost exclusively to people who have it as a weekender/summer car. I don't even have room to keep the spares for this one, let alone another car.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
