I had no probs just make sure its reputable dealer on ebay.
The other really good bang for your bucks is LEDs-parkers, no plate, boot, doors,interior
try this.
http://www.ebay.com/bhp/g35-clear-side-marker
I would have to disagree in regard to the LEDs.. they cost 'bucks', but return zero 'bang', unless you just like a different colour light.. Plain old lamps do the job just fine.
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7170414
How would you know - have seen them or tried them ?? Has nothing to do with colour!- they are brighter and more effective. Driving down a driveway you can actually light up the walls either side with your parkers.The interior is much better and allows you to find things at night- especially those with dark trim. If you like I will buy you a pair there only about $12 at supercheap.
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7170456
try this.
Thanks mate! Perfect :)
As for LEDs.. My MR2 has all of them done so if they're the same fit then I will swap them all over :)
My V35 has white parkers and xenons but they said they're taking them off for compliance. Hopefully they leave them in the boot or something so I can whack them back in. Huge fan of white/blue lights on cars compared to the dated yellow look!
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7170470
Yes, have tried interior lights.. I found the brighter interior lights too bright at night and switched back to the standard bulbs.. but if you like them.. fine. I have a torch in the glove box for finding lost stuff in dark parts of the car.
Parking lights are not supposed to be bright, it will probably make them illegal if they are too bright.
No. Plate lights.. well, they don't really need to be any brighter.
There has also been a few posts of issues with the interior lights not working properly with LEDs.
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7170543
They are perfectly legal- they are brighter not too bright !-they use less power and produce less heat.making them safer and should be more durable. Friends have had them for years without changing one. Last of all the colour emitted is much nicer! Ive had them iver a year- no issue.
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7170551
Sure if you like them then go for it. The main benefit is the range of colours if you don't like the normal incandescent colour.
Also in the 12 years I owned a J30 Maxima, the only 'bulb' I ever replaced is 2 interior dash lights. I wouldn't be surprised if LEDs have less lifespan than decent quality automotive bulbs.
I see some companies now selling 'loading resistors' for those that have retrofitted LEDs and have issues with their car electronics, they are designed to present the same electrical load on the cars electrics as normal bulbs.
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7170579
If they are "designed to use the same electrical load" - why would they need load resisters?. The only situation you may need these is if you use more powerful LED's than the standard amperage ( which is crazy as they brighter anyway)Or you try using them where theres inconsistent power supply such as indicators.- which is not what they are designed for.
Everyone knows standard tail light fitment on the V is LED's. They are more effective and durable.I have had my car over six years without changing one and I doubt anyone ever needs to.
Like anything if you use them correctly they are , brighter, more efficient, and more durable. Its ok if you dont like them but stop talking BS and scaring people from using them - just because you dont know what your on about.
Btw - the guy just told your hes had them in his MR2- so he knows more about them than you do.
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7170602
Lol.. I forgot it is still school holidays.
in regard to 'speaking BS' -
1. It's call 'current', not 'amperage'
2. the additional resistors are designed to present the same electrical load as the original bulbs, as the LEDs normally don't, unless they have such resistors intergrated.
3. Decent quality automotive bulbs are easilly as durable, I have seen plenty of cars driving around with LED brake lights in the rear window, or rear spoiler with half of them not working. - and as I said.. 12 years in my old J30 without a single failed brake, parking, indicator or headlight bulb.
4. at no point did I try to 'scare' anyone from using anything, I just disputed your 'really good bang for buck' claim.
Facts -
1. LEDs are useful if you want a different colour without using filters on the bulbs (which reduce light output), they draw less power or produce more light for a given power rating, run cooler, and can have a decent lifespan, unless you buy cheap dodgy ebay LEDs which have a lifespan of about 12 months..
2. LEDs often upset car electronics.. there has already been a few threads in regard to people having the 'auto dimming' feature of their V35 interior lights not work with LEDs. And some reporting 'failed brake light' warnings on some cars due to the reduced load.
3. To make sure we all understand, I will repeat myself in capitals - USE THEM IF YOU LIKE!!!
18 years in the broadcast electronics industry has given me some knowledge of what LEDs are and how they work..
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7170636
Can you actually read!- of course people with auto dimmers are going to have problems- LEDS are not designed for dimmers or switches with inconsistent/variable power input.
All your other gibberish just confirms what I said about them.
18 years in broadcast electronics wont fix your short circuit kid.
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7170720
So why are you argueing with me??
Hmm.. wrong yet again.. LEDs work perfectally fine on suitable dimmers, it is the dimmers that have the problem.. they don't like the reduced load of the LEDs in these cases..
Anyway.. I'm out.. you go back to your 'amperage' now.. :)
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7170959
hello to all V36 owners out there,
previously a long time skyline owner and have taken a break for the past 2 years (went down the EVO path) now soon to be back to ye' ol' skyline.
looking at the v36 sedan Type SP 3.5L 2008.
Is there any known common issues with these cars?
i've read up something about the cam sensor failing being common
is there any difference between the 06-09 models?
would you v36 owners be kind enough to list down any issues you had with your car.
Thanks
If you look around and read some of the threads on here, you will see that the 06-07 models seem to have a software problem that makes driving the car a nightmare and apparently 2008+ dont have this problem. Have a read of this thread mate
http://www.skylinesaustralia.com/forums/topic/430930-v36-rev-probs-firmware-update-anyone/?hl=%20v36
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7171088
Hi all!
Just picked up my 04' 70th anniversary just over a week ago now and I'm f**king loving this car.
The car is pretty much a blank canvas at this point.
Planning on over the coming year or two:
- Clear side indicators
- Computer language conversion + buttons
- Slim white licence plates
- Window tinting
- Ztube to stock airbox
- 350z Engine cover
- Suspension upgrades (sway bars, strut braces etc)
And less important stuff
- Plenum spacer
- Somesort of exhaust (not sure of what, want to keep a muffler at the end)
- OEM cruise control unit
- Wider 19" wheels
....and to fix
- Remote key (does abolutely nothing)
- Passenger side door lock actuator
- Some of the rubber seal stuff under the driver side door looks like it was hit with something and some of it came off.
- Clean out the massively long red hair I found underneath the centre console :S
Also, can anyone tell me what those little microphone looking things are on the dash? There are 2 of them.
Cheers
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7171972
^ Car looks MINT man! I just bought a similar white 03 which I'll be getting in a week or two so I'm sharing your exact same excitement right now haha
Looking forward to seeing what you do with it :)
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7173339
Hello, I'm Davo and I'm new to the world of V-Series. Here's mine, details in the info bit to the left. Erm... no plans for it other than general ownership and some reliable motoring, a welcome change to the 1970s horror stories that I previously had...
2555e886-b3f3-4414-8935-1c3b41a8b953_zps
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7182910
Very nice! The wood grain is a nice finish.
It has 2 subs? Where?
2 small (about 8" I'd say) subs in the rear shelf. They don't have a whole lot of punch compared to my 12" but it still vibrates the rear window (can see it in my mirror haha) :happy:
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7185666
  • 1 month later...
Got my car and did the first mod! Nice GPS/DVD system from my old MR2. Sounds great on the Bose speakers in my V35! Didn't realise it had 2 subs haha
Awesome woodgrain finish mate. Did your car come with it or did you upgrade that too? If so how? I have a very similar one like yours, same color and model, but I havent upgraded the stereo yet. I am planning to put an after market single din in the place of the CD-ROM under the glove box. To put the after market stereo in the front dash I would need to buy a dash trim kit, which I don't really know where to source locally from (sydney) except for ebay.
https://www.sau.com.au/forums/topic/191705-newbies/page/43/#findComment-7225457
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
