Welcome blade. I dont know if its changed but my HID on my V35 S2 2005 were disconnected on compliance (2007) & I had to refit them. It had something to do with matching the right Aust standard which wasn't available at that time- I would think it should be ok now. I cant be sure for the Stagea but should be very similar. On the V35 it wasn't that hard to put back- make sure the compliers give you the wiring and the HID fitting or get them to fit after its registered - its perfectly legal to have them- just the compliance
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742088
Yeah it seems that this is still the case. Sadly my compliars were very 2nd rate, I can't get answers nor a reply from them.. So looks like I'll have to spend some hard earned soon and rectify it.. Will have to start looking into getting some genuine replacements, car hopefully is delivered today, so I'll hold off until I have a list on what I need.. Can only assume ballast & globes..
Many thanks
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742705
The reason the hid's are removed is because they don't meet the ADR standards (toss, toss) for being self levelling and having water spray jets. Silly as it sounds, that is the reason because in Australia we know more than the rest of the world.
You should ask the compliance mob to give you the globes and ballasts removed from your car if they did indeed totally remove them.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7742746
Blade511- Your compliers should NOT keep anything from your car - ITS YOURS. You should demand and get it back- its nothing short of theft!. I have no idea why anyone would touch ballast other than to steal it (which is usually a big job to remove anyway). Usually the wiring is disconnected from behind the headlights & somewhere in the engine bay/wheel arch, the they just modify a bracket / wire for standard globes!.Noone should be touching your ballasts!. They are about 750new (if you can find one). I know because I had to change one ($220gen 2nd hand one). I was lucky I had a friend comply it and the compliers talked him /me through every detail, they kindly bundled the wiring and bulbs in the Glove box. I was very lucky my car still has the jap warranty card for the impul chip and fujitsubu exhaust, spare key + vallet key. If anyone took anything from my car They would be very very sorry..!. You know the car has it- go there & get it!
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745136
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745139
Could not agree more.. I've been on one hell of a back and forth and am starting to get results.. But they are painful and am at the point where enough is enough.. Put simply I don't want to deal with them any further. And would be happy to send them a bill just to stir.. However, you and I both know that I'll be wasting my time when it gets down to the nuts and bolts of it.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745461
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745462
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7745464
  • 4 months later...
  • 2 months later...
Hi guys,
I'm looking to buy a 2008 nissan skyline 370gt v36. It's an import with navigation system and stuff in Japanese. That's fine, but since I have never owned an import car before, I would like to know if spares are readily available in WA? Or in the eastern states? I'm getting an inspection report done as well. Anything I should keep in mind when I go have a second look and drive? Your advice and help will be greatly appreciated.
Thanks.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7809295
  • 1 year later...
Here are some pictures of my latest buy, a 2005 350GT auto.
Driving buy the local car yard & spotted it on the lot for $10990NZD. Had a look on the web-site & found out it only had traveled under 50,000k so I decided to go have a look. Took it for a spin, loved it, so I bought it!
Runs on 17s, has black cloth interior, factory tinted windows & no wind deflectors over the doors (which spoils the look).
I got a gadget that plugs into the cig lighter socket to play music from my phone through the factory head unit.
The pictures ain't the best but had to take them between heavy rain showers from my phone.
https://www.sau.com.au/forums/topic/191705-newbies/page/49/#findComment-7881710
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
