i've been meaning to fix up my crappy suspension for a while .. right now its screwed as there are low springs at the front .. i dont' know which ones .. and there are normal ones at the back ... so my choices are either coilovers or springs ... i've had a hard think and i've come to the conclusion that springs are a better choice due to cost ... coilovers = 1k plus camber kit ... so thats about 1.5k when everything is done .. i'd rather spend that money on other things like sound system or mags or even for a rainy day ... what i want to know is ... how many of u guys are running kings on stock shocks?? have u had any problems?? was the handlin much better?? what are the different spring "levels" i can get? will i have camber problems as well??
thanks
https://www.sau.com.au/forums/topic/19172-king-springs/
i know this probably isn't relevant cos i dun have an r33 but ive put 1.5in lowered king springs in my hr31 with standard shocks. Im pretty sure they are progressive rate springs and although they have a much higher spring rate than standard, to my surprise they are almost as soft as the originals. got em on special for $250 all round from car toys. They are fine for the moment but you gotta get 4 konis or biltzienz aswell......
https://www.sau.com.au/forums/topic/19172-king-springs/#findComment-402834
My mechanics apprentice has King Springs on standard shocks on his R33 and says it is worse than the standard springs. It handles like a bag of @#$*. I've put Pedders springs on mine and am quite happy with them. I will eventually get new shocks though. The stiffer springs don't quite match the standard shocks properly.
https://www.sau.com.au/forums/topic/19172-king-springs/#findComment-402843
You will find the standard shocks with uprated springs will tend to make the car bounce all over the place as the standard shocks aren't up to the task on dampening the stiffer springs. Thats what mine did, when I added the Bilsteins all round it was a totally different car, handles great now.
https://www.sau.com.au/forums/topic/19172-king-springs/#findComment-402952
hi hip,
i had kings lows (1inch lower) with std shocks, and the handling was without a doubt better than with the std springs. I had none of the bouncing that was mentioned, perhaps my std shocks are in good nick?
either way it will handle better than what youve got now! as ive seen the rake angle your running!
I tried to order superlows, through autobarn mile end, and apparently they dont do them anymore. And anyway, lowering more than an inch is detrimental to handling unless you get coilovers.
even with 1inch lowered i had mild camber problems, the inner rears got eaten out pretty quick (thru lots of launches and wheelspinning tho).
So basically if your going kings, youll be getting the lows (1inch). If you remember last time you sold me the wheels i mentioned i had a set of lows? still have them, 6 months use if that. I will prob sell them if you want, but i need to see how the ride is with the new teins before i do -im back in adelaide next week.
Pm me if your interested dude and we can meet up, prob looking for around 200 bucks? paid 290. Depending on how much time i got, might even be able to fit them for you too.
https://www.sau.com.au/forums/topic/19172-king-springs/#findComment-403064
this what i did, bilsteins with king springs, great combo. to the guy that got the pedders, u got yourself a set of rebadged monroes mate.
https://www.sau.com.au/forums/topic/19172-king-springs/#findComment-403778
I was thinking of getting some King Springs for my R33 too with the standard shockers. I saw some really cheap ones on ebay brand new (actually not sure if they are cheap) $90 for a pair of low (30mm) and super low (50mm). The reason I think it is cheap is because the guy at the tyre shop wanted $380 to get my car lowered with the same springs. So if I buy these and install it myself, will be saving $200 :)
I just hoping that it is easy to put in and handle better and not worse!!!
Cheers
https://www.sau.com.au/forums/topic/19172-king-springs/#findComment-404043
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
