I am currently in the process of rebuilding my rb26 out of an r32. I am rebuilding it because the oil pump started playing up as they so often do.
I got the N1 pump and the pump collar. The motor looked untouched when we pulled it down. It is now getting put back together and the crank is in. The guy who is putting it back together is now telling me that there is no way that he can get the oil pump collar on. He also says that the pump is currently a perfect fit, and that I don't need the collar. My thinking is that of course it fits, but I should still need the collar. He is adamant that the collar is exactly the same dimensions as the fitting on the crank. I haven't seen it yet.
My question is, can I check my engine number to see if the block is from an r33 GTR?
And, does anyone know what might be going on?
Thanks in advance.
https://www.sau.com.au/forums/topic/191720-pump-collar/
post model change R32 GTRs have what is effectively an R33 GTR sized oil pump drive. If the 'flats' on the collar are the same as the flats on your crank then for sure don't fit it. Also, the collar doesn't just slip onto the crank (so I've been told, haven't done it myself). But it makes sense that you would need to machine down the old surface, then fit the collar.
what year and month was your 32 GTR made?
https://www.sau.com.au/forums/topic/191720-pump-collar/#findComment-3448507
Apparently you have to heat treat the collar to fit it on, and that's fine. The problem is that it seems to be like 5mm out. It just seems like a lot to machine. The motor should be an early model r32 one (December 89), but who knows what's coming out from Japan.
https://www.sau.com.au/forums/topic/191720-pump-collar/#findComment-3448542
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
