Hey guys and gals, i've just recently joined the the forums, and I'd like to introduce myself. My name is Roald, but you can all call me Roo.... its easier :)
Now, I don't drive a skyline, but i do have a RB30DET (25/30) in my VL Calais, and I figured this would be a good place to get some good info on the newer nissan tech, as the VL sites i've become accustom to are more 'SOHC oriented'....
I have some Q's regarding my setup etc. but I'll get to them at a later date (studying....)
Looking forward to getting involved,
Regards, Roo ;)
https://www.sau.com.au/forums/topic/191734-new-act-member/
  • 4 weeks later...
Ok, so its been a while.... I've been busy finishing my CIT course - flat out!
Here are some pics and info from the prevoius owner. I would have loved to do the conversion myself, but this came along and was far more cost effective :)
Engine
7,000 km's old
3ltr, acid cleaned, crack tested
bored and honed 50 tho to suit oversized pistons,
shot peened rods. New mains, big ends, small ends, balanced etc.
genuine Nissan head gasket
reconditioned RB25DET cylinder head with extra provision for VCT,
ceramic T3 turbo driven only on 6 psi
3inch exhaust with high flow cat
New bosch 910 fuel pump
Custom braided lines for turbo
Nizpro engine bay mounted intercooler
Wiring harness professionally modified to suit vl
Gearbox
R33 turbo 5speed manual box
Pulled down for inspection before fitting
Short shifter
Harness and speedo modified to suit vl
Heavy duty clutch,
shaved flywheel,
Fully balanced and modified drive shaft to suit r33 box
148RWkW and 530Nm on 6 PSI, std. R33 computer :)
Will get more pics up later on some time.
Cheers, Roo
https://www.sau.com.au/forums/topic/191734-new-act-member/#findComment-3502555
148rwkw? :huh:
Are you sure that figure is correct? You should be making a lot more than that...
No offence intended.
None taken :) .The reason for such odd Power vs. Torque figures is due to a rather restrictive intercooler. Between about 2100-3300 rpm I have access to full boost (10p.s.i), but by the time I've reached 4500 rpm its all the way back at 6 p.s.i :) You can see on the dyno sheet where the boost really falls off. Once its gets up on the revs, the cooler simply can't flow enough air.
Correct me if I'm wrong, but I think this setup should really start singing at around 4000/4500 rpm, right where its all over....
I'm condisering sending the cooler to Garrett for a recore (Nizpro tanks are good as far as I know?) and getting the turbo high-flowed/steel wheels. Any other recommendations? Will I need a fuel cut defender (sometimes it surges/cuts under boost at lower revs - i.e. full boost to manifold) or rising-rate reg?
Thanks for any input,
Roo
https://www.sau.com.au/forums/topic/191734-new-act-member/#findComment-3507884
None taken :P .The reason for such odd Power vs. Torque figures is due to a rather restrictive intercooler. Between about 2100-3300 rpm I have access to full boost (10p.s.i), but by the time I've reached 4500 rpm its all the way back at 6 p.s.i :( You can see on the dyno sheet where the boost really falls off. Once its gets up on the revs, the cooler simply can't flow enough air.
Roo
If I may voice my opinion... :)
Well if you want to get the most from your engine set up (RB25 / 30DET) then I would suggest a fairly large low mount turbo such as a Garret GT30 / 82R, dont bother high flowing the one you have.
Im using a GT30 / 71R (slightly smaller than the 82R) and it is good for about 250rwkw, the larger GT30 / 82R will be better for your engine because you have more down low power because of the larger capacity and it will probably spool a larger turbo pretty quick.
If youre going for out right power then you will need a fuel pump - go for a Walbro in tank or Bosch 040. You'll also need to upsize your injectors as the standard ones will max out pretty quick, go for some SARD 550cc brand new squirters, dont bother having the standard ones high flowed.
As for your intercooler, I have been using a Just Jap / Cooling pro 300 x 600 x 76 front mount for a while and Ive never had a problem, I would highly recommend one for the price.
Get in contact with GCG in Sydney for the turbo, Powerflow injection for the pump and injectors and Just Jap for an intercooler.
Im using similar equipment in my RB25DET (550cc injectors, 040 pump, GT30 / 71R and JJR front mount) and my car makes 230rwkw and 550nm at 18psi, very conservative AFR and it has bugger all lag.
:D
Edited by Bullet32
https://www.sau.com.au/forums/topic/191734-new-act-member/#findComment-3517303
Great, thanks for the info :P
For the moment its on hold due to a matter of funds, but I will definitely take your advice into consideration. I have been considering dropping the whole lot into an R32, but again this is more likely to happen later rather than sooner, once I finish my apprenticeship :P
BTW, anyone know what a good R32 rolling shell might be worth, just out of curiosity?
Cheers, Roo
https://www.sau.com.au/forums/topic/191734-new-act-member/#findComment-3524527
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
