UPDATE:
After weeks of trying to find some rims that would suite the color and the lines of my car, i decided to settle for 18" Gravity Gullflame in Gold colour, 9.5" wide.
It's really essential for me to get the widest tyres available for a R33 GTST, so i was thinking 275's at the back and 245's at the front.
The 9.5" width rims come in these offsets: +15, +25 and +35
.. and the 8.5" width rims come in these: +25 and +35
Should I go both front and rear the same width rims? or Should i perhaps go 8.5" for fronts?
What is the ideal offset for front and rear wheels?
Do you think i could get same offset rims for front and rear on a gtst?
Help me plzzz..
Old post:
I've been lusting over these wheels lately, but can't seem to figure out what brand they are.
They can't be Wedsport SA-70's, although they look very much alike.
Can one one help me?
Edited by Barbarian
https://www.sau.com.au/forums/topic/191751-what-are-these-wheels/
Guys, another question.
What would be the best (like in that photos of Silvia above) for a R33, offset wise ?
The offset of the car above isn't THAT good. I mean it's got a wider body, but the wheels aren't close enough to the guards in my opinion. The front are alright though.
Try using this calculator mate.
http://www.1010tires.com/WheelOffsetCalculator.asp
Just experiment with different offsets and width to see how much the wheel comes out and see if there's enough room under your guards.
Thanks adam, much appreciated
God bless :rofl:
Hi Adam
In my defense, those pics were taken when I had a set of Ikeya Formula rear lower control arms in place and before I had a chance to get it aligned. I've since fitted the stock rear lca's and sold the Ikeya Formula ones (overkill for a daily), and the offsets are much closer to perfection. See the pics on the following post for proof:
http://www.sillbeer.com/2007/10/sillbeer-r...ther-stuff.html
Note that there's too much camber on the passenger side as it's yet to have an alignment (which will be happening tomorrow).
Cheers
Brendan
Help me plzzz..
Hi Adam
Cheers
Brendan
Sorry mate, I didn't mean to offend you in any way. Seeing that the car is used as a daily, I'm not surprised it doesn't have its tyres 2mm from the guards. :happy:
It's a beautiful car though mate. I'll be lucky if any of my car's will look like that. Take care of it.
Cheers
No wuckers mate. I was more surprised the many that putting the stock arms on would set the wheels up for almost perfect offset to the outside of the guards. But haveing said that, it means I can't lower it drastically without dialing a whole lot of camber in to tuck the top of the tyres under.
Cheers
Brendan
Help me plzzz..
If I were you I would go with the 8.5" at the front and 9.5" in the rear. I wouldn't have a clue how much clearance there is between your wheels and your guards, but I can help you out if you can get me some information.
Your current wheel specs:
I'll need your, wheel width, offset, diameter, tyre width and profile.
Your new wheel:
Just give me your desired width for the front and back and I'll work out which offsets I'd recommend.
Also how much clearance there is between your WHEEL and your guards front and rear.
If you get me that information, I should be able to help you decide which offset to go with.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
