I know everyone has probably read that and said to themselves why on earth would you want to do that!?
Here's my situation. After wanting an R34 since i was old enough to feed myself the time has come when my hours upon hours of hard work have paid off and i have saved enough to get one. Problem is that, well, i'm on my P's and those lovely restriction laws in victoria mean only n/a skylines for me. After reading extensively through these forums the consensus seems to be that if i buy an n/a skyline i'm going to regret it further down the track. okay enough beating around the bush, basically i want to know if its actually possible/a good idea to get the 25gt-t, rip the turbo out (essentially making it a 25gt) then pop it back 2 years down the track when i'm off my p's and a competent enough driver to handle a 208kw 'line. Also how costly would the whole taking the turbo out procedure be?
oh and i appologise in advance if this is a completely stupid question and not actually possible, my knowledge into the mechanics of cars is very limited at best!
I think you may find that even though it is a good idea.. it wont work..
the car may not physically have a turbo, but in vic roads/cops systems the car will show as being a turbo model and you will get done for it, plus it would be over the power / weight ratio.. dont quote me on this tho just going of stuff off the top of me head lol :)
u sir r a tool, sell the car and buy a gt ull make some money to
theres that many things that u would need to change to make it a NA itll cost so much its not funi,
plus as jezza said vicroads classified it as a turbo model as it will also b classifed
sell ur gtt and buy a gt
Hi.
There is plenty of info around mate, so ill be locking after this post as we have gone into it at length.
To summarise for you.
The car is still build-plated as a TURBO. So it is therefore illegal.
You would need to have it re-complied with EVER single proper NA factory part on the motor.
Right down to brakes/stud pattern/NA motor/exhaust and so on. Removing the turbo doesnt essentially make its a NA... as its still the turbo motor :)
So simply put, it would cost you well over $10,000 i reckon. By the time you sourced all the parts, labour to convert.
Compliance fees, Engineers fees and so on.
So buy the NA, drive it for a few years (inline with the law) and then sell up and buy a turbo
Cheers
Ash
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
