Make:R34 GTT 5Sp/ MY2000
Model: S-Tune
Milage: 47,747Kms
Colour: Pearl White
Currently registered? NSW
Price: 28,500 NEG
Contact: 0423865077 SMS Appointment only
Comments / Modifications:Nismo S-tune Body part,NISMO Exhaust ,Nismo Driver Seat,Nismo Speed metre,Nismo Strut Bar,Nismo Suspension,GANADOR Mirror,Nismo GT LED Taillamps
1Year All State Warantee,6 Months Rego Available to test Drive.**Fast Finance Available**
Regards
Images:
Edited by em456
https://www.sau.com.au/forums/topic/191813-fs-r34-gtt-s-tune-28500-neg/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
