Street Figher Emulator
Tosh
 Share
I've got Street Fighter Alpha 3 on ps1 (as well as EX1 and EX2) I also have SNK Vs Capcom 2 on ps2. Street Fighter rocks :( I can't get enough...
get MAME and u can play online around the world...best to play guys around Australia. I've played Street Fighter Alpha 2 and kicked everyones as$ cos I had a joystick hehehe
Originally posted by EnricoPalazzo
Evil: U wanna burn SFA3 for me?
u can download the rom for it...it's around 20 megs I think...just use google and search around, u need a emulator 2 run it though, like MAME, Neo Geo, Final Burn etc... for SFA3, I'm running final burn and MAME. I've also got a kick ass arcade joystick for arcade feel :)
Ok if i download the ROM, then how do i use that on my PS1? I cant i think i have to use it on the computer only?
u can't use a rom 2 play it on the Playstation. Rom is for the emulator to be used only for the computer. But some ppl are hacking the roms and emulators and releasing stuff like Sega Master system 255 games' on 1 cd for the playstation (cos I have it ;) )
so are u looking for SFA3 for your Playstation? Or for your computer?
cos if u want it for your Playstation, I can give it 2 u as a trade if your interested..here is the list of what I got.
I just got hold of a cd thats got all of the Street Fighter series that were released for PC. Havent tried them because the cd had all the Mortal kombat series which i like more :D .
If you look around you can find people selling the entire mame series on cd (10 cds with over 4000 old arcade games) :) but you have to pay for em. :D
Originally posted by Leon.T
Evil, u any good? I'll give ya a challenge :D
I dabble a bit here and there (lol) I got sick of beating little kids at highpoint so I just play at home on ps1/2. What about u Leon.T? I'll challenge you one day... :P I used to play with a capcom emulator but lack of a good joystick (lol not that type of joystick) made me give it up. ps1/2 from here on in.
hehe yeah! highpoint has only little kids.. I go to city now to get real challengers. I play KOF, Tekken, SF, mostly anything.... I used to be very good but haven't touched it in a while
oh yeah, there is going to be a tournament this Saturday @ Highpoint for Soul Calibur 2. I will be entering that tournament. U wanna come and watch (or enter) :D it starts 10 am....hope u get to read this before then....
I would have gone. I missed ur last post. Sh!t... :D
Tell me when the next one is on... I'll come along :D
Are u going to MAS this Saturday?
 Share
    • Well.... yes and perhaps no. It depends on what you mean by "spool". For most of us, the point that we would describe as where the turbo is "spooling" is the point where the wheel speed gets high enough for it to start making some boost. This is coincidentally around about the point where it starts making noise - hence the "spooling" sound. If that is what you mean, then no - the wastegate should still be shut at this point. The boost will still be way below the point where it should start opening. If, on the other hand, you mean "spool" as "reach full boost", then yes. At the point where the boost has reached target, then boost control has already started. The wastegate is already open, and has been for some time. Some short time, definitely, but still, some time. If you have no boost controller - just the wastegate actuator connected to the boost source, then you have a mechanical system working as a pressure balance. There is pressure on one side of the wastegate actuator's diaphragm from the spring, and pressure on the other side coming from the boost measurement location (the "source"). This is not a digital thing. The wastegate does not stay shut until the boost pressure reaches the spring "pressure". The spring will start to compress as soon as you start to apply any pressure onto it. This can be controlled somewhat by adding pre-load into the spring, but you cannot add enough preload to make it into a digital switch behaviour. The wastegate will crack open and start to leak exhaust out (and therefore not though the turbine) well before you reach the target boost pressure. Electronic (and some mechanical/pneumatic) boost controllers will act to prevent the boost source applying pressure to the actuator until just before you reach target boost, thus preventing the wastegate from creeping open. And some boost controllers will apply boost pressure on the spring side to further push it shut. And this can be be necessary because the exhaust pressure in the manifold also pushes on the wastegate valve and tries to open it and you cab get it leaking even without it being connected to the boost source.
    • A stand alone boost controller will not give you the control you need, unlike a modern ECU. Your boost will always naturally target the wastegate's opening pressure first, your controller then will allow you to add more boost as required.
    • I recently discovered that I could not remove the outer bolt on one of my rear UCAs. Looked like it was seized to the crush tube. It wasn't all that long since I had last had that arm out (I dunno exactly, but certainly <2 yrs), so I was a bit surprised. I thought I had stock bushes in the rear knuckles, so I ordered some new PU bushes and resigned myself to having to do some dismantlery....and some butchery. It was clear that the seized bush was going to need to have the bolt cut out of it and then possibly some more brutality after that. Upon getting the 3x arms on each side disconnected from the knuckles (with the exception of the seized one, of course), I discovered that I had in fact put PU bushes into the knuckles when I did the subframe conversion about 12-13 years ago. So, I say "Oh, good, I might not have to swap any of these others out". We set to work butchering the bolt out of the seized arm. Stainless blade in a big-arse Milwaukee recipro made short work of it, and also damaged the arm, which added a welding and grinding and painting step to the whole exercise. During the butchery it became clear that the bolt was not just seized but bent. Head scratching ensued, as it is hard to understand how that bolt could get bent. I did suffer a broken (stock) toe control arm on that side a few months ago, and drove some miles with some significant rear wheel self steer and lack of control, which probably was the cause. But it's still hard to understand how it would bend that bolt, rather than just bend the arm. But here's the start of the real discoveries. The crush tube was rusty as all shit. I mean seriously rusty. A little on the inside, contributing to the tube seizing to the bolt (along with the bend). But the outside had at least 2-3mm of compressed flaky iron oxide jammed in between the parent metal and the PU bush. This one was brutalised and still took some effort to get the PU off the crush tube. So I thought I'd inspect the others more closely. The one on the tension rod adjacent the bent one was first. I had to use a 2-jaw puller to get the crush tube out, and it took some effort. It came out looking like the first one. All 6 of them were the same, except for one that looked not too bad. Had some corrosion on it, but was mostly OK. There was also a significant amount of corrosion on the inner surfaces of the knuckles. They took some convincing with pointy tools to let go their grip on the inside of the holes they were in. There was no sign of the original (SuperPro) lube anywhere. I and my bro-in-law have never seen any crush tube end up looking like this. It was seriously like the car has spent time putting boats into the water at the boat ramp. So, it seems like the PU might have been bonded to the steel on both sides, which would have to make them work more like stock rubber bushes (where arm deflection results in twist inside the rubber). Despite this, I have never had cause to believe that they were so tightly bound up. The suspension moved up and down much as you'd expect. The car never made any noises in those bushes that would have led me to believe there was a problem. Maybe the rusty interfaces actually were "sliding". Anyway, lesson learnt. Even quiet, non-troublesome PU bushes should be inspected every now and then!
    • the boost controller allows you to adjust the opening of the wastegate (which only has one preset spring) I'm going to see how it acts on it
    • I studied the principle of wastegate to begin with. so if I understood correctly. the moment when the turbo "spool" is where the boost control begins. When the target level of "psi" is reached the wastegate opens to regulate the exhaust pressure passing through the turbo and thus control its speed and the rate of boost
