Hey everyone whats up got a wideband problem and wanted to see if anyone on here could help me out. Car is a 95 gts-t mods are pod filter with cai, fmic, 3.5" turbo back exhaust with split dump no cat, boosted up to 12 psi, stock ecu and turbo with afc neo. Ok here is the prob got a PLX wideband O2 SENSOR installed the O2 sensor in the decat pipe wired it up correctly and everything got power and the instructions stated that no calibration is needed but if you let it get warm takes 45 sec and it is exposed just to normal air the display should read air did that and air appeared on the display. Now here is the dilemna ct the car on let it get warm reset my afc neo cause Im thinking all is good and I'll be able to tune the afr's myself so I let the car get to normal operating temp took a look at my display and it reads 19 now Im cruisn at 1500 rpm to try and get the afr's right for that rpm and the display says lean and the more gas I put in the the richer it gets but i set the afc neo to +50 and the lowest afr I got was 14.5 I think!!!! What the hell is goin on. I thought skylines with stock ecu ran rich why are my afr's so lean at cruise and I did it at idle and the same thing nothing below 14.5 WHEN I have added +50% on the afc neo and when I set it back to 0 it shows lean. Can any1 help?
https://www.sau.com.au/forums/topic/191844-wideband-o2-sensor-not-worth-a-fk/
Possibly try and recalibrate with the o2 sensor out of the exhaust.
On cruise your stock o2 sensor and ecu should have the mixtures fairly close to 14.5, even with a few mods. Have you got bigger injectors which may be a bit laggier than the stockers?
So you can't really tune at cruising cus what I was trying to do was tune the car to get the afr a bit lean at cruise, no I have stock injectors, still it doesn't explain why the wideband would read lean at idle and lean on the wide ban is anything over 20 there is no possible way for me to be that lean at idle with the stock ecu and no tune and like I state I had the afc neo to the max which is +50% and the afr's went to 14.5 at idle. Could the distance of the wideband O2 senor affect readings cus I have it right before the decat pipe.
sensor is too hot. i get a similar probem on mine when the sensor gets to hot. and there is no point trying to tune a safc on low revs/cuising or idle because the car goes into closed loop and "tunes" itself.
Is there any fix for the sensor getting to hot? Also how can it be if the max heat for the sensor is 850 C?
there are some very specific guidelines to follow and take note of when using a wideband 02 sensor
the main ones i can think of is
mount the sensor in the right position (location and the way it faces)
the sensor must always have power when running
be closest to the turbo outlet as possible
that being said ive had a wideband sensor up my exhaust muffle and it worked fine
be closest to the turbo outlet as possible(I thought it ad to be at least 24 inches away from the outlet for accurate readings at least thats what the instructions said)
After reading that I think I figured out the problem the a$$hole that welded the bung for my O2 sensor placed the O2 sensor in the bung and it was in there for a week or so with no power to it while the car ran its daily errands. So I think the O2 senor is destroyed, damnit and I just bout it, Man guess I gatta shell a couple more bucks out for another wideband O2 sensor.
double check but i remember reading that having the sensor in the exhaust and no power certainly can kill it
then wideband sensor i had in my car was hard run off the battery terminals so you couldnt cut the power to it
this also made sure the sensor was heated up correctly
So even at ignition off your sensor was still on even when you took the key out your sensor would still be on?
yes this is correct, as its a portable wideband sensor kit and not a permenant one it was setup to be temporarily setup like this on your car
so that it ran as soon as the earth terminal was connected. instead of being say on a cigarette lighter plug that could be bumped or unplugged they chose to direct hard wire it.
if you run the sensor in the exhaust stream and it looses power you risk frying the sensor, hence the hard wire method so it cant "loose" power
only took about 30 seconds to install
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
    • If you need to refinance your mortgage and reset the loan terms back to 30 years and cash out on your equity for "investment" purposes *cough* car parts, I can help 😊
