It is with great delight I introduce you to Tyler John, born Thurs 1 Nov at 8:20pm. Weight 9lb 10.5oz, length 52.5cm. Needless to say, he is a big boy :)
Carolyn and Tyler are both doing great. He is quite alert and generally very happy. Have only had a couple of tiny cries and I got a solid 6 hours sleep last night (can't say the same for Carolyn though).
We couldn't be happier! I dropped home quickly to pick up some things and am off back to the hospital for the next few days, so will receive your well-wishes/responses when I can. :ermm::dry::(
https://www.sau.com.au/forums/topic/191889-its-a-boy/
Congats Andrew, Well done to you and your wife, Glad to hear all is good and well!! I bet you can't wait to have a Pale now the pregnancy is over and the new born is safe and sound??
So straight to the business............ Now comes all the Hotwheels, Tonka Trucks, Bikes, and of course saving for a Go Kart....
https://www.sau.com.au/forums/topic/191889-its-a-boy/#findComment-3451539
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
