Hey people, bout that gold engine bay.
Ive tried to contact the seller on ebay twice with no luck. Anyone else had a go and got a reply.
I asked if the goldness made it the super dooper R33 "G spec" go harder.
Could also be the new "gold-dilla" people are ravin' bout!!
Nahhhh, jokes aside....no response!!!
EMZ
It looks to be a Series 2 that has had a front end crash. The owner probably realized or couldn't find series 2 head lights and bonnet because they're rare to find and expensive and just used a 4-door series 2 front bar. In any case I wouldn't be touching this car. 'ONE OF THE FASTEST IMPORT RACER' This unintelligible comment would turn me off the car instantly.
lol half these jokers dnt no wat it is..mate its a series 2
the front lights,front bar,its got the abs thing inside the enginebay whereas series 1 and 1.5 dnt.
the wing also is series 2.the front bar looks like a series 2 bar but looks like its been changed a lil not sure hes got shit pics.
Thanks for the heads up mad82.
Also just to let people know ive tried to contact the seller of the R33 with the custom gold engine/bay and currently awaiting a response. Ill posta again when i have an answer!
EMZ
When you call Abdul Rauf on 0430093068.
Tell him his car stinks. :P
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
