you don't really buy a GTS for power. however if you do want a little bit more there are a number of things;
-nitrous
-turbo conversion
-rb30 conversion (engine transplant though)
-intake
-exhaust
-cams
-timing
-ecu/piggyback
a search on any of those keywords should yield more details.
if you're interested there's a group buy currently in the works for extractors.
http://www.skylinesaustralia.com/forums/t189629.html
we don't really need more threads for 'how to get more power', there is a plethora of information on the forum with extensive details and results. give them a go.
when i get time i shoud write up a sticky thread collating all the data.
theres plenty of threads on this even a couple i had heheh
but for my N/A with out goin into too many high tech mods
air/pod filter
extractors
exhaust
with a good setup it should give you raise in roughly 20-25kw if your lucky
this is what im planning on getting done then rims and maybe bodykit later on
Dont waste your money, take it from a guy who owns the same car. Spend your money on a nice car entertainment system. Trust me you would rather have a sound system than the 20kw because you wont notice the power i guarentee you that.
Save your money until you get your full license and get a GT-R.
yeah it all depends how much $$$ you got to spend...i did headunit, amp, sub n speakers first..at the end of the day if you tihnk about it not point wasting thousands on power only to go the speed limit fair enough exhaust cai n that but wouldnt recommend much more unless your serious about your car and its power output...just my opinion though. gl
a 20kw increase where? top end, mid range, low rpm??? the kilowatt is one thing, driveability is another.
you'll be saving a long time to own a GTR :w00t:
correct. unless you intend on fully utilizing the mods for (bragging rights not included) there's no point.
even some of the 300HP GTSTs are being wasted cruising from carpark to carpark...
..guh.. >_<
Can we please Sticky a unversal "How do I get more power?" and "What do I need for my exhaust?" thread!?!?
In all honesty.. there isnt much you can do to get decent power out of an RB25DE without taking out the block..
As said before.. pretty basic plan is
Intake
New cams
Ajustable cam gears
Port and polish
Shave/deck the block
headers
Zorst
ECU and re-tune..
Work your way through that.. and you should be sweet..
I suppose if all done well you could get 160kw.. perhaps?
You could always go a 3L bottom end.. Could have you pushing 220kw.. perhaps..
With NA engines.. dont aim for a "larger power figure" thats all bolocs.. aim on making your engine more resposive with a larger powerband..
Hey man, im sortah in a simillar boat to you, i been doin alot of reading and i think ive worked out the best way to get the most out of my car without goin to far overboard... i have a 96 s2 r33 gtst (turbo version) so this is my rough action plan (if urs is non turbo just ignore the turbo components). First thing i did was car alarm, tinted windows, car stereo, and 19" deep dish x factor rims... then i did the increase boost mod u see on these forums to bypass the dual stage boost and set it to a constant 7/8psi... and these r my plans for whats commin next... (in no real order)
96 Nissan Skyline R33 Series 2 GTS25T
Future Modifications:
- Exhuast - full 3" split dump and quality 3" high flow cat keepin size all the way to the back, mandrel bent with high flow muffler
- Intake - Apexi POD Filter with cold air box and cold air intake (this will allow u to hear turbo without need for BOV)
- New Springs to lower the vehichle
- R34 GTT Side Mounted Intercooler
- Turbosmart dual stage boost controller OR R32 Wastegate Actuator to increase turbo boost pressure to 10/11psi
- Turbo timer
- Neons
- Apexi Power FC ECU upgrade
- Dyno Tune
Edited by Alex_r33s2gts25t
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
