high flow cat, 2 1/2 from cat back in to lukey turbo muffler 2 1/2" in 4" out (3 chambers straight through design, fibreglass noise suppresion doesnt work :D) working on gettin extractors, everyone else here should have extractors pretty soon im guessing from the group buy!
  • Replies 43
man than that is a fat score!!! i love the dragger exaust and if i ever buy another car its the only system i will ever put on, it doesnt drone at 100k's sounds awesome all through the rev range and gives my car a really deep tough note but is not at all overly loud so u dont get all the attention from the cops but still get all the go that a good quality exaust should give u.
EFI hardware in Mitcham Vic haev throttlebody detups with trumpets and fuel rail for $2500 for a RB or L series engine. But if you're able to measure up and sketch out a rotary throttle style system you could probably get a engineering shop to know one up for about 1K.
Guest Dark Sky 33
hey,
just wondering if anyone knows wats the go on getting an air intake system for my n/a r33, i want to get one cos i was told it would increase performance a little bit
wat do u guys reckon, wats the best and how much do these things cost?
p.s. not just the pod filter, the whole lot
cheers
adam
Cold air induction can make a massive difference if done properly. The colder the air the larger its density and thus the more molecules that can combine with fuel giving a bigger burn charge. But more power will usually only result if your air temp sensor and fuel map can adjust to the air temp change, which should be the case on a R33's map. Plus the denser intake in cruise conditions should give better fuel ecconomy. All provided your filter doesn't clog.
yea ive got the same setup you'll notice the difference straight away it pulls harder at high revs with the filter in the bumper bar
ive also got the coby extractors and a 2.5" cat back system
best mod i did was the extractors really made a big difference the car sounds better revs smoother and revs quicker
in the next couple weeks ill be getting a full rebuild stroked to 2.3L multiple throttle bodies and SC
im just trying to be a different as possible so we'll see how she turns out :D
  • 3 weeks later...
just a quick question... i've alread got a 2.5" Kakimoto zorst from cat back. while the muffler... 2.5" in and 4.5" out... soon enough when i get my cash back on track im going to get the rest of the zorst done as well as extractors...
anyone know a rough est. on how much the rest of the zorst will cost me as well as the extractors and wheres the best place for a reasonable amount of dough down in melbourne?
regards..!
get coby extractors from nz - check out the info in the group that was done about a month ago - extractors u'll get for about $300 and install for about $100 and get a hi-flo cat (about $300) and/or a straight through pipe (for track use only!)
check out Daalder Exhausts in Box Hill - speak to Matthew - he's a great bloke and really good to talk to - can tailor make a system depending on your requirements - loud/quiet/whateva and is really good on price!
well i just got my extractors fitted today as well as a 2.5" hiflow cat. It cost $440 for the fitting and the cat which isn't too bad. Mr Muffler in Lilydale did the work. If you go there ask for Tim, tell him Greg sent you and he'll hook you up with a good price.
I'm really pleased with the extractors. The engine revs a lot more strongly and a lot smoother. The torque gains in the low to mid rev range are massive, the car is not so slow below 3000rpm as it used to be. with 3 passengers in my car tonight it was still performing fairly well where as it used to feel like an excel. the only thing i don't like about the extractors is the loud sucking noise from about 3000rpm onwards, it sounds like a vacuum cleaner. I'm considering putting the stock airbox back on, anyone want to buy an apexi pod and fibreglass cold air box?
those of you have have the coby extractors fitted, what have you done about a head shield? the intake pipe is too close to the extractors for my liking. if it doesn't melt the intake piep it will definitely increase intake temps. any suggestions about what to do?
regards
greg
EDIT: do not use mr muffler in lilydale, i have since discovered what a poor job they did. eg reusing an old broken gasket, not using split washers and leaving drops of weld in the cat causing the exhaust to sound like a tin full of money being shaken :)
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
