Guard Rolling/flaring
BIGDADDY1
 Share
needs more flush dave. Looks kind of mexicana atm.
still yet to finish it, and fitment doesn't necessarily mean covering the whole thing. i like lip of guard on the top edge of the tire sidewall.
  • Replies 77
Posted Images
  • 3 months later...
  • 5 weeks later...
  • 1 month later...
ive got one that looks the same as the burson one. i think i picked it up for 150 a couple of years ago. the rear nylon nut did wind off but that's only because i went hard out on it. it was a simple fix of don't be retarded and don't wind so much pressure on it all at once. it has worked for 2 other people who i've lent it to. no complaints
i wouldn't go and buy the expensive one unless you were a shop.
  • 1 month later...
  • 4 weeks later...
i got one i think a paid around 200 for it
its made by a company that has the word "trade" in it, they should be able to look it up in the book and order it in
i found it to be an ok roller but, i improved it and now it never breaks on me
the cylindrical shaped block that the thread screws through sometimes slips out of the rectangular tube that it sits in as the cylinder isnt a tight fit, i fixed this by welding 2 washers exactly the same diametre (beleive it or not nissan head stud washers) to each end of the cylinder, and it hasnt slipt out once yet
  • 1 month later...
Hey guys, need help on guard rolling. I have just put a new front end on my car and the front guards need to be lip rolled and slightly flared. The reason why is the wheels have spacers front and back and dont want it to scrub.
Can i buy a tool that will do both of these? or when you roll the lip it flares the guard anyway???
If the tool is only 200 bucks or so, i will buy one and do it myself
I can do all steel fabrication,custom piping,tig welding and want to learn to do guard rolling! can anyone
help me out with this???, Thanks
Hello friend ,
Have you heard of Barts guard ?
Just now i came to know that barts guard come to your place and do each guard for something like $50 per arch.....
You can even consult them about buying which tool and for what price !!
 Share
    • FWIW, I've always found Toyota A/Cs to be much colder than Nissan ones. Even that 2024 Nissan X-Trail (that VW Australia lent to me), the A/C isn't as cold as other base model Toyota Corollas/Camrys, etc. Maybe Toyota A/C compressors are superior?
    • Hurry while stocks last! 🤣 13% points redemption on this $6000 Mont Blanc "James Dean" ballpoint pen at Yodobashi Camera in Umeda, Osaka
    • It's not that at all....I just love the R chassis too much to keep racing it! Absolutely impossible to fix the damn thing if I bend it.... That last off I had (when I neglected to do what Kel said), we removed a gum tree with the side of the boot....needed a new rear quarter, boot lid, floor straighten, rear bar, front bar, both front guards, radiator, bov return and I still haven't got it back for a proper alignment to check it is actually straight again). There are just too many ways in tarmac rally to do significant damage to a car that you can't really get parts for.
    • Now I'd said earlier I'd checked the fuses, and per @Stick180's suggestion I checked them all again. The check was to use the multimeter in continuity mode on the top of each fuse where the little metal tabs are available for that purpose. All good....except that very "A/T Control" fuse was actually blown when I pulled it out and looked at it. Put it back in, tested it again, there is continuity to both sides even though the fuse is blown. I'll need someone smarter than me, but my suspicion is that I was getting a circuit through a power supply, through an incandescent globe somewhere, to earth, to the shorted wire and back to the other side of the fuse, making it look like the fuse was OK when it wasn't....please anyone that understands this f**kery explain it to me. Bottom line....that suspicious purple/white wire, in an undamaged factory loom, that goes to the the wrong place in the fuse box has a dead short to earth, confirmed from both ends.  How a single wire in a factory loom can be shorted, especially the best protected loom in the whole car (underneath the top of the dash) is going to keep me awake at night because surely whatever caused the damage has (or will) damaged other wires in that loom too. So, to finish this long and sad story....cut the purple/white wire where it exits the fuse box, ran a new wire from there to the ECU loom pin 31, fired it up and drove happily into the sunset. Only 4 days of head scratching and peering into footwells to get me there. Another collection of wire removed (in addition to the earlier photo) and a bunch of 10a fuses that gave their lives for the trouble shooting....thank you for their service.  And, since the car was in the shed I resealed the cam cover (first time I've ever had a new seal leak on an RB, but the Stagea is that kind of lucky), and I put in the boost doc cam splash plates to try and turn down the blow by a bit while I was there. Which, was all good because it also let me find the slow coolant leak, turns out it was from the turbo water supply which I nipped up again (the banjo bolt got new washers, and I tightened the hose end and hose to banjo fitting while I was there)
