  • Replies 77
Posted Images
  • 3 months later...
  • 5 weeks later...
  • 1 month later...
ive got one that looks the same as the burson one. i think i picked it up for 150 a couple of years ago. the rear nylon nut did wind off but that's only because i went hard out on it. it was a simple fix of don't be retarded and don't wind so much pressure on it all at once. it has worked for 2 other people who i've lent it to. no complaints
i wouldn't go and buy the expensive one unless you were a shop.
  • 1 month later...
  • 4 weeks later...
i got one i think a paid around 200 for it
its made by a company that has the word "trade" in it, they should be able to look it up in the book and order it in
i found it to be an ok roller but, i improved it and now it never breaks on me
the cylindrical shaped block that the thread screws through sometimes slips out of the rectangular tube that it sits in as the cylinder isnt a tight fit, i fixed this by welding 2 washers exactly the same diametre (beleive it or not nissan head stud washers) to each end of the cylinder, and it hasnt slipt out once yet
  • 1 month later...
Hey guys, need help on guard rolling. I have just put a new front end on my car and the front guards need to be lip rolled and slightly flared. The reason why is the wheels have spacers front and back and dont want it to scrub.
Can i buy a tool that will do both of these? or when you roll the lip it flares the guard anyway???
If the tool is only 200 bucks or so, i will buy one and do it myself
I can do all steel fabrication,custom piping,tig welding and want to learn to do guard rolling! can anyone
help me out with this???, Thanks
Hello friend ,
Have you heard of Barts guard ?
Just now i came to know that barts guard come to your place and do each guard for something like $50 per arch.....
You can even consult them about buying which tool and for what price !!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
