Going to be purchasing a Nismo stripe set and mayb a windscreen decal.
Where can i go to get these applied professionally?
As i know if i try, it will be uneven and i'll probably stuff the stickers up.
if you apply them wet you will be able to line them up fine
get a spray bottle and wet the panels then lay the sticker on top and keep moving it till its right
once its right press em on and get all the bubbles out and it will be fine
if not go see Taran at ApexGFX
http://www.apexgfx.com/default.htm
  • 1 month later...
As 2GU UP said.....spray bottle to apply them wet so they can be adjusted. A chalked string is pulled tight across the side of the car to mark a straight line. Im sure these are availiable from bunnings or sumwhere, even a 1m ruler and a crayon works fine.
