  • Replies 54
I standard manual chaser will flog a standard manual R33 according to the specs I read in high performance imports (i'm not sure about R34s). They easily crack 13's when stock. The twin turbo 1JZ is an absolute ball tearer. They are a fair bit lighter than a soarer even with the extra 2 doors. Apparenty some importer is staring to get heaps of them now.
https://www.sau.com.au/forums/topic/19196-toyota-chasers/#findComment-404281
manuals uncommon?
Not so, there are lots, but there are more autos. That's a fact - I was looking at them in a japanese car classified mag during lunch. I've been thinking of getting one as a daily driver to take home (4 doors are handy), but my other half doesn't like them - she thinks they look like a magna crossed with a bmw. I have to agree, but I've seen a few stunning examples - very nice when bodykitted (a bit like the r34).
https://www.sau.com.au/forums/topic/19196-toyota-chasers/#findComment-404457
curious..
the 97 or so models look a bit like a verada from the front and a bit like an older BMW from the back?? Apparently they are one of the vehicles that are now available under the new scheme
I still think i'd still go the soarer though if i was going for that sort of thing...'cause i want something cheap :(
Here is a couple of nice pix of them so u get the idea... its a bit like a different looking 4door R34
https://www.sau.com.au/forums/topic/19196-toyota-chasers/#findComment-404673
and to think toyota australia had two cars to pick from when they brought out the avalon
the avalon a us market designed car (which the new camry is better than, so the avalon is a waste) and the chaser, but in toyota australias great wisdom they went with the avalon
idiots.
https://www.sau.com.au/forums/topic/19196-toyota-chasers/#findComment-404789
chasers run 14's on a real drag strip, are no quicker in that regard than a skyline.
A friend of mine's family yard has had the RAW's certification done for the chaser/MK2 recently , it passed the side impact tests with flying colours. What an expense that RAWs thing is! He had to send a Stagea over to get side impact tested (they basically wreck it) and if it passes then its got to do emissions tests and things as well. For every car that gets the Aussi tick one poor car has been sacrificed.
https://www.sau.com.au/forums/topic/19196-toyota-chasers/#findComment-405668
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
