I feel your pain mate. I lost it once when I was concerntrating. Also lack of experience I think. Only had the car 3 weeks, wasnt used to the power or rear wheel drive. Having bald tyres didnt help either. Lost it and took out a fire hydrant. Im the unofficial cause of stage 3 water restrictions. Lucky for me it was minor damage. I feel really bad about the amount of water lost though, the bloody hydrant was going for an hour. =(
PS: car was covered by full comp and is all good now. The sig pick is the side that was hit, front right. As you can see, you cant tell the difference. Now its got nice fat new tyres on it.
Edited by DogKnight
  • Replies 53
Oakliegh Repairs will replace/fix the following parts
AIRBAGS
DASHBOARD
BONNET
HEADLIGHTS
WATER PUMP
HARMONIC
RADIATOR SUPPORTS
FRONT BAR (MODIFIED NON STOCK BUMPER)
REENFORCEMENT
GRILL
WINDSCREEN
RADIATOR
CLUTCH FAN
a/c CONDENCER
RECIVER BOTTLE
BONNET LOCK SUPPORT
WASHER BOTTLE
THERMAL FAN
BELTS WHICH NEEDED DOING
7k INCLUDING PARTS,LABOR & RESPRAY!
hrmm are you sure its worth to pay $7k to fix it?
How much do r33 gts' sell for these days?
Might be better to sell the wreck and purchase another gts? as the car may never be the same after it has been repaired...
i bought that 5 month ago for 13 k
i know i could buy like a shitty commo or something
but i love the car too much
its like
if your pet was sick.. and you could pay 2000 to make him better or 500 for a new pet
you wanna fix him
you could probably make 4 -5k selling all the parts, then plus the 7k that you need to spend to fix it is around 12k which would easily get you another gts that has not been in a smash, or hold out and get a gtst.
my friend has same sort of front end damage, his mechanic told him to go to the wreckers to get a "front nose cut".. should include most of what u need, except bonnet, lights, and belt from what i remember.. but its hard to find nose cuts.. should cost $1k i hear.. but if u find it, it could save you money..
also the airbags cost a shitload to replace.. 2000 + i think..
the money isnt so important as much as getting the car back asap
plus i dont wanna be hunting down shit
i like the idea of
i give to man
man fixes
man calls me when i can pick it up
    • Knowwhatchatmeanforsure.  I really want one, but as I already have an IC7 I don't think I'll ever be able to justify the upgrade.
    • I managed to get a video of the car running. Maybe the car is just idling normally? I showed this to one of my mates and they thought it was normal idle. I thought it was a small/slight cam(?) or something else. What do you guys think? https://drive.google.com/file/d/1aAcmgWzjstK-AqQgph2TTL2RPQWgTbbf/view?usp=sharing
    • Yeah. I think Moog's GTR was set up with a stock looking layout on the UC10. It looks good. And that you can connect many direct connect signals to it, use it as an input extender for the ECU, etc. Which means for me, it is almost desirable, because I could mostly/sorta use it against a Nistune ECU. But it's a lot of money to drop for an almost/sorta thing. KnowwhatImean?
    • Have you seen the firmware changes so now everything is customisable on the dash?
    • Yeah, The UC10 is the first of these to make it all the way to "acceptable" to look at.
