Hi everyone.
I remember hearing that R32 and R33 GTSt diffs are the same except for the back plate to allow for a different hicas rack.
Is this correct?
Reason is that there aren't many 2nd hand diffs for an R32 and I have a backing plate from an R32.
I'm after a stocky to put a 1.5 way centre into it.
thanks,
Russ
https://www.sau.com.au/forums/topic/192019-r32-r33-gtst-diffs/
I've been chasing the same for the same reason.. also to go to 4.1 ratios. I have been informed that the crown wheel bolt pattern is different, if you find out otherwise, let me know :)
It you haven't bought the diff yet, I think you could just buy an 1.5way suited to a 33 maybe.
I've been chasing the same for the same reason.. also to go to 4.1 ratios. I have been informed that the crown wheel bolt pattern is different, if you find out otherwise, let me know :P
Nah I want to start with a new diff I know all about unless if one comes up cheap enough.
Surely somebody knows?
the backing plate is different.
The front mounts are different. you need to machine up a bush and press it in.
The crown wheel bolt pattern is the same. This one is actually a bit of a myth as there are actually different bolt diameters in the r200 centers but i'm pretty certain that the r32 and 33 ones are the same size as r32 actually has the larger size bolts. Doesn't matter really as there are converter bolts available from nismo that have a larger shank to suit the larger hole in the center and a smaller thread to suit a smaller crown wheel bolt size as used in s13 ratios (3.9's). pretty certain i have some floating around somewhere....
Thanks mate. Same ratios too?
nah, s14 ~3.7 from memory, s13 ~ 3.9, r33gtst ~ 4.1 and r32gtst ~ 4.3.
very roughly. A bit of research can confirm the exact ratios available. there are a few ratios in between and i think the r32gts4 is close to 4.4
Hmm so I should be able to bolt an R33 crownwheel to my R32 Nismo diff? just need to utilise converter bolts with a thicker shank?
I have been given so much conflicting information over this! I want to drop the ratios a bit as 4.3's with the RB30 is a bit too short.
Thats worst case. You'd need to confirm the bolt size on the crown wheel once you have the diff open.
Ahh OK, so if I grab myself a 33 diff it should all bolt up I just MAY need some converter bolts?
By the sounds of what I was previously told, it wasn't going to work at all and I needed to stick to S13/R32 diffs.
so... in theory... i could also buy an r33 diff to bolt up into my 32 for lower cruising revs...
I am sitting on 3100 rmp at 100 clicks...this seem far to high?
Yeah but it's only 5% difference. So 2945 rpm instead of 3100. If you do, sell me your R32 diff.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
