NISSAN SKYLINE R34 GT-T
90000 km
Silver
QLD
RWC supplied
Currently registered
25500
0406245968 but preferably email me [email protected] n ill get back 2 u
NISSAN R34 SKYLINE GT-T RB25DET
*210+rwkw
*260+ km/h
*custom intercooler and piping
*race suspension
*3 inch custom exhust system, high flow cat and cannon
*hks ssq blowoffvalve
*Apexi power fc
*Apexi AVC electronic boost controller
*Apexi Turbo timer
*Defi temp gauge
*Defi oil pressure gauge
*Defi performance recorder
*Aftermarket bodykit
*18 deepdish chrome rims
*Kenwood head unit
*Genuine Nismo gear knog
Images:
https://www.sau.com.au/forums/topic/192023-r34-gt-t-4door-wit-mods/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
