Hey,
For a while my mates Rb25 has been running low compression in cylinder 6. A compression test showed that all cylinders up to 5 are around 150 or so psi but number 6 is around 47psi. Happened after running 2.0Bar Boost for a while. Also after His interior was stolen his HKS EVC IV Reset, now when ever he turns boost to high he gets backfire and the car doesnt want to boost sometimes. Any Ideas on the problems??
https://www.sau.com.au/forums/topic/192047-a-couple-problems/
may be hard to sell without fixing it.
could be many things so its hard to say, but if your losing compression, there is a leak in your combustion chamber so either a ring problem, valve problem or head gasket problem. all of these are not cheap
