Styline GTR Posted November 3, 2007 Share Posted November 3, 2007 Hey guys, Have a Stock R32 GTR and in need of some help for some upgrades! Can the Stock Standard Ceramic Wheel Turbo's be converted to a Steel Wheel Ball bearing turbo and if so how much am i looking at and where do i get it done? Does a POWER FC Make Much difference to Power gains? Or is it Just Easier to get a Bolt on upgrade like a set of GT2860R-7?? Link to comment https://www.sau.com.au/forums/topic/192064-what-to-upgrade-to/ Share on other sites More sharing options...
The Mafia Posted November 4, 2007 Share Posted November 4, 2007 Does a POWER FC Make Much difference to Power gains? I think you need to do a search, or even use google and learn a little bit more about cars and their systems before you ask questions like this. Link to comment https://www.sau.com.au/forums/topic/192064-what-to-upgrade-to/#findComment-3453666 Share on other sites More sharing options...
cheez Posted November 4, 2007 Share Posted November 4, 2007 stock turbos are running 10psi if im not mistzken, they are more than capable of running 1 bar(14psi) without going boom. power fc is a great upgrade for any performance car. it makes some difference even on a standard car. you have to remember that the factory tune is restrictive and set to comply to the japan regs, well worth the $$$ with regars to ur turbos, depends on your power target. if u chasing big targets, change them. if your chasing smaller ones leave them the standard ones til they go boom and then change. y waste the $$ on new turbs if u dont need to. decide your power taget and then your decision on turbo selection becomes easier. Link to comment https://www.sau.com.au/forums/topic/192064-what-to-upgrade-to/#findComment-3453675 Share on other sites More sharing options...
MrStabby Posted November 4, 2007 Share Posted November 4, 2007 Can the Stock Standard Ceramic Wheel Turbo's be converted to a Steel Wheel Ball bearing turbo and if so how much am i looking at and where do i get it done? You can rebuild the standards with steel wheels and plain bearings for ~$1800. GCG can probably do it. Or is it Just Easier to get a Bolt on upgrade like a set of GT2860R-7?? For ball bearing turbos, yes. That'll cost about $2500. Either way you'll then need to pay for gaskets, and fitting if you get someone else to do it. What's the power goal? From memory of other posts the rebuilt stockers will probably go to ~270awkw, and the smaller of the 2860's around 330awkw. Spool time will be a tiny bit better on the stockers. Link to comment https://www.sau.com.au/forums/topic/192064-what-to-upgrade-to/#findComment-3453860 Share on other sites More sharing options...
MrStabby Posted November 4, 2007 Share Posted November 4, 2007 stock turbos are running 10psi if im not mistzken, they are more than capable of running 1 bar(14psi) without going boom. I think age needs to be taken into consideration. Newly rebuilt could probably run 1bar without to much issue, but turbos with over 100,000km (the maintenance interval) would be pretty risky. if your chasing smaller ones leave them the standard ones til they go boom and then change. y waste the $$ on new turbs if u dont need to. But you might then need to cough up for an engine rebuild as well. There have been more that a few cases of exploding turbos sending nasty bits into the engine and trashing it. No idea of how often that happens tho, so I cant judge the risk. Link to comment https://www.sau.com.au/forums/topic/192064-what-to-upgrade-to/#findComment-3453872 Share on other sites More sharing options...
Styline GTR Posted November 5, 2007 Author Share Posted November 5, 2007 Thanks guys! Still so hard to choose! New turbo's, Hi flow stock one!!! ARRRGGGHH!!! Link to comment https://www.sau.com.au/forums/topic/192064-what-to-upgrade-to/#findComment-3455752 Share on other sites More sharing options...
