Make: Ford
Model: Fairmont
Milage: 98300
Colour: Pearl Blue
RWC supplied?
Currently registered? yes
Price: 14500ono
Contact: 0402371782
Comments / Modifications: standard has a standard duty haymann reece toybar
Images: pm for pics.
i want to get a r33 gts-t/200sx wth basic mods (exhaust, filter, fmic) and would swap for the righ car.
Edited by simonr
https://www.sau.com.au/forums/topic/192107-adl-ford-ba-fairmont-14500ono/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
