Hi,
I have just purchased a 1996 Series II R33 GTS-T and have a few questions which I was hoping you guys could shed some light on.
Q1. I was driving today and noticed that my oil pressure was sitting around the 2 mark until the car warmed up and I started driving a little more "enthusiastically" when it went to around half way (4), is this normal? The car has a FMIC, Oil Catch Can, Pod Filter, boost controller (only set to 7psi).
Q2. This one may be hard to determine, but I jumped in the back and noticed that both of the rear door trims were not attached properly, they are just sitting there needing to be screwed back on! Is this likely to be something from when it was complianced (I am the second aussie owner)? I just wanted to see this if this is common...
Q3. It looks like I need a new front windscreen seal as part of it has broken away, is there an aftermarket one that fits the R33 and is easy to get hold of? Is there anyone who has had this done? and who by?
Q4. The 4th gear synchro is grinding (seems to happen more as the car warms up), I have done some reading and it appears this is relatively common and the Redline gearbox oil is the way to alleviate this, is this the consensus amongst those of you that have experienced it?
Thanks in advance,
Steve
Edited by sly033
https://www.sau.com.au/forums/topic/192138-new-member-questions/
Yes normal, at least in my GTR with 5-40w oil, sits higher with thicker oil.
No idea, but yes get them screwed in.
no idea
Yes comon occurance even in my GTR, a good gear box oil will assist but no guarantees it will fix the problem.
Q1. - Normal, especially if youre using thin oil such as 5W-40 etc.
Q2. Best thing to do is take them off completely and check that all of the trim plugs arent broken and replace them if they are.
Q3. Any windscreen reparier will be able to fix gaps in your windscreen seals.
Q4. My gearbox was very clunky and used to grind into 2nd and 4th until I replaced the oil with Redline Synthetic Shockproof oil... Its dear as poison but works wonders, its worth trying.
There’s a consensus that specialty g.box fluids fix most syncro issues. Redline helped my box going into 1st while rolling, as well as a small nick when shifting from 3rd > 4th
ahh, that's great to hear that I can do something about it..
Does anyone have a set of wheels I could borrow for rego? The previous owner used spacers in the front in and I just need something to get over the pits to change the rego over before I address the issue of getting new wheels etc..
There would be beer / wine / other involved for whoever can help me :D
Cheers,
Steve
Just remember that it only assists in changing the gears, at the end of the day, its still f**ked and you dont want the box giving way when you least expect it. Having said that, it does work well for its intended purpose.
R33 GTST RB25 gearbox = Very very strong... I dont think that its going to give way just because it crunches into 4th. There's a reason that these gearboxes are put behind big power SR20DET's Silvia's and 180's and RB30ET/DET's in VL's etc. its because they are almost bullet proof (if youre not an idiot who cant drive).
My box has been ground, crunched and clunked since I first got it about 4 years ago and since putting redline shockproof in it I havent had any troubles with it.
If you want some redline shockproof for a reasonable price ($20.99 a Liter needing 4.5L for R33) send this guy an email (Performancelub.com) .
I buy all my oil and spark plugs there, ridiculously cheap if you can find other people to join in to lower the postage cost (postage at a set rate of $25 per box, 1 box fit 6 spark plugs, 5x 1L engine oil and 5x 1L gear oil with room to spare). I need more engine oil soon so if you want to split the postage 50-50 send me a pm, anyone else that wants to join just post here.
He sells Castrol, Mobil, Royal Purple, Redline and NGK products.
These gearboxes are very strong items but definitely are not bullet proof with any car with decent power being able to strip gears and synchros as quick as you can throw at em.
As these gearboxes are usually subjected to high rev gearchanges the synchro's are prone to damage. if your synchro is crunching then redline will only work for so long as the damage is already done.
Best to get it checked out by someone who knows as no two gearboxes are the same and while one may last four years others may only last four months as metallurgy is not an exact science on factory gearboxes.
I think what datto260z is trying to say is better to catch it before it causes any more damage.
Anyone who has worked on gearboxes will tell you it is cheaper to just replace synchros rather than replacing shafts and gears which is what will end up happening in time.
Try the rdline or even better the NEO gear oil but expect to pay a hefty price and no guarantees.
Yeh thats all im saying. I know how strong they are and that it probly wouldnt give way like that, but if anyone is considering making a substantial amount of power, then its worth doing the extra work. But for lower power and not much hard driving, yeh for sure its worth it.
    • I used to have Walbro 255's when they were a pretty common update. (or were they 044? 040?) In any case I had a dirty tank. I thought the tank was good, but I would find the filter would clog in maybe ~50km of driving. If the issue persists, well, your fuel system or tank has crap in it that the pump is sucking up.
    • Hi. Ok thanks for the info. I/we do not know what tune is on that Nistune ECU so it is why there is stock ECU and that Nistune is for later when the car is done. I have guy who tunes Nistune and other ECU so i will then take it to him to see and properly tune for the car   And for the update. On 99,9% it is bad fuel pump. Which is wierd cuz it is like 2 years old(brand new walbro 255) and that filter (also brand new) was dirty.  I was alwaya pumped premium(100) on very good petrol station so i dont know how is that possible...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
