how you going guys, im a lil new to the whole GTR thing so need a lil help.
i just got my self a R32 GTR the other day...... AND I LOVE IT>>>
its got a rebuilt engine done mid last year, in the re-build they have put, ARIES Forgies, eagle rods, tomie lifters, sard fuel reg ladlaldalda... bit more bits in pieces..
now i need to know at what temp should my car run at... ATM it sits a lil above half way. iv been told its normal.
also whats the standard boost.
and with the engine as is whats the max boost i can run with standard turbs
cheers
https://www.sau.com.au/forums/topic/192144-nooob-to-the-gtr/
should run at about 78 degrees (water temp)
oil temp depends on where your measuring from.
anywhere close to the middle of the stock gauge is probably fine, as long as the engine pretty much stays there and doesnt fluctuate too much
standard turbos i would run less than a bar, if the engine was rebuilt they cant be far behind. at the same time, i wouldnt do all that without changing turbos anyway, its a bit of a waste.
[/quote
yhe i asumming that the previous owner had after market turbs on there, as well as aftermarket comp.. pitty i didnt get it
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
