Hi guys
Got a series 2 R33 Skyline GTST here for wrecking, pretty much a complete car except it's been hit on the passenger door/rear quarter. Whole front end available! and everything else... engine, gearbox, etc.
PM me if ya need any random parts not listed
Engine:
Sold
Gbox:
5 Speed Manual conversion kit! everything ya need: 5 speed box, clutch, flywheel, tailshaft, clutch and brake pedals, clutch master and slave cyl, shifter, etc. $1800 ONO
Exterior bits: (Colour code KR4)
Bonnet - $350
Guards, with GT badge and blinker - $160 each or both for $300
Radiator support + latch & horns, etc - $220
Series 2 fog lights $300 pair
Fuel Flap lid - $15
Brake/Suspension/etc:
Front upper control arms - $100 pair
Drivers rear upper control arms $50
Drivers Front lower control arm $50
Front hubs $80 each
Engine/exhaust bits:
Window wiper bottle - $20
Radiator overflow bottle - $20
Stock sidemount - $40
Steering rack, great nick, recently reconditioned - $120
Stock cat $30
Interior Stuff:
rear seats - $80
Floor carpet - $90
Roof lining, no marks! - $40
Battery tray - $40
Rear interior pieces set - $100
Grab handles (set of 3) - $20
Slightly negotiable on some of this stuff so reply here or send me a PM!
Located in Sydney. pickup only on the big stuff, everything else I can post
Cheers
3" Front pipe with opening for split dump(blocked off) $100 Ono Sold
Brake master cyl & booster - $80 Sold
Radiator with shroud - $130 Sold
drivers side mirror- $50
Front seats Sold
Rear view mirror - $30 Sold
Rear pods - Sold
4x GTST wheels/tyres, 2 of the wheels have some small marks on them (see photos). rear tyres are about 50%, fronts 70%? - $260 ONO Sold
Series 2 AFM (pink sticker) $120 Sold
o2 sensor - $35 Sold
Rear 5 stud hubs - $180 pair Sold
handbrake drums + cables $200 pair, or with the hubs as well $350 Sold
Rear standard shocks & springs, as new condition - $100 pair Sold
Stock airbox with panel filter - $70 Sold
Fuse box cover - $30 Sold
charcoal canister (large type) - $30 SOLD
Catback exhaust, Jasma muffler, 3.5 inch piping before muffler, I think the rest of it is 3" - $300 ono
Steering wheel with airbag, great nick - $190 Sold
Dash cluster, 90,000k's - $100 Sold
Climate control - $65 Sold
gear surround plastic w/ ashtray - $50 Sold
Larger dash piece, with clock etc - $100 Sold
All seatbelts (x5) - $100 Sold
Centre console with lid- $60 Sold
Headunit brackets - $25 Sold
Sun visors - $30 pair Sold
Steering column surround plastics- $30 Sold
Floor mats complete set (x5) - $140 Sold
Front Nismo (Tokico?) shocks(damper adjust knob?) with unknown springs - SOLD
Rear lower control arms $60 pair Sold
Space saver - $50 Sold
Front bar reo - $150 SOLD
A/C fan - $40 SOLD
Front calipers & pads - $300 SOLD
Front Rotors, good nick - $100 Sold
Rear calipers & pads - $150 Sold
Rear Rotors - $80 SOLD
R33 GTST diff great nick - $200 Sold
Drivesafts - $60 pair Sold
Headlights, immaculate SOLD
Grille - $70 Sold
Bootlid, no wing, has lock & cover $50 Pickup only!
Passenger side mirror- $50 SOLD
Rear tail lights, No leaks! Sold
Rear bumper $50 Sold
Side skirts, some light scratches/marks, needs a little touch up - $100 pair Sold
Edited by phatlavish
https://www.sau.com.au/forums/topic/192162-r33-skyline-s2-gts-t-wrecking/
  • Replies 79
Could be keen on the driver seat..
Could i get pics from all angle pls..
Also is there any rips etc?? i need a perfect condition one!!
Perhaps the passenger seat then? could i use that as a driver seat? will it work
Any chance you could post up some more pics of the skirts?if they are in good condition i will take them!!
And would you be willing to ship them to n.z??
Cheers
Edited by nizmo_freek
would u separate the headlights? because i need a driver side headlight
Sorry mate, looking to sell them as a pair
Hi mate, just wondering if you would be willing to seperate the just the turbo from the engine pack you have here? if so how much would you want for it?
Looking to sell it together with the engine at the moment
Also looking to sell these as a pair. Unfortunately passenger seat wouldn't work because the controls would be the wrong side
Do you have the glovebox/lock and key??
yeah mate got the glovebox with lock and latch and all that, no key $40
Cheers
Theyre too much/too much trouble to post unfortunately, Looking for a local buyer
All pm's should be replied, let me know if I missed ya!
Cheers
I will take the headlights at asked price if you confirm they are immaculate. i.e. no scratches (turn lights on then look at them from various angles). Im in syd so can pickup.
Interested in r33 weather shields if you have any too
PM me about either
Edited by Xizor
hhaha didnt think of that..
Well let me know if you willing to seperate..
cheers
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
