  • Replies 79
Do you have the hose that goes from the firwall to the aircon compressor? Its next to the turbo and is wrapped in heat protection foil type stuff.
Yep still have that piece, PM sent
the 3in front pipe still available? where bouts in syd are you located?
Still have that too, pm sent!
hey mate im chasing driver side switch for power window and possibly driver side power midow motor? thanks luke
Sorry dude they're both sold
will u post the drums?
sorry these just sold a few days ago
have you still got the headlights?
Nope sorry they're also gone!
Everything left in the list on the first post is still available though
hey there just wanted to know what the best you could do on the engine and is there any chance i could come and see it.where are you located.you can txt or call me on 0400 726 727.i dont care about the turbo as i got one.cheers sam
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
