  • Replies 626
Posted Images
Why do Beer Baron and Abu seem to elongate the page by fivetimes in my firefox browser?
Anyway my favourite is my much modded GTS4 but unfortunately it has to go. :)
ENGINE & MANAGEMENT & COOLING & BRAKE:
TRIAL RB 2.4 SPEC
TOMEI FORGED PISTON KIT/RING
NISMO TIMIMG BELT
HKS RACING PLUGS/LEADS
AIR COND COMPRESSOR ASSY
NISMO INJECTORS
BIG CAPACITY AIR FLOW/M
HKS GT2530 TURBINE KIT
REINFORCE ACTUATOR
EXTENSION KIT
HKS OIL COOLER
APEXi INTER COOLER SRS
ROM TRIAL TUNED CPU
FRONT PIPE
CATALYST ADAPTOR
240 L/H FUEL PUMP
HKS BOOST EVC3
HKS SQV
APEXi SUPER CATALYST
ENGINE DOWN
POLISH TO VALVE
SIM ADJUSTMENT
VALVE TIMING ADJUSTMENT
CYLINDER BORING
CYLINDER HORNING
POLISH TO CYLINDER BLOCK
POLISH TO CYLINDER HEAD
ADJUSTMENT TO METAL
TOMEI 82mm PISTON KIT
HKS METAL HEAD GASKET
HKS CAMSHAFT IN&EX (264Deg)
HKS CAM PULLEY KIT
BLITZ RACING RADIATOR/CAP
NISMO REIN-FORCE ENGINE MOUNT
NISMO REIN-FORCE MISSION MOUNT.
SPOT WELD BODY
N1 WATER PUMP
NISSAN OIL PUMP
ORC TWIN PLATE CLUTCH ORC-709-01N
HKS EIDS (TYPE-H1) IDLE
GEAR BOX ASSY
TOP FUEL SUPER RELEASE FORK
OHMORI OIL PRESSURE METER
OHMORI OIL TEMP METER
OHMORI WATER TEMP METER
JOINT ADPTOR
2 DIN ALPINE/SPEAKERS
OS GIKEN SUPER LOCK LSD SPL TYPE
EARTHING KIT
HKS POWER FLOW
SARD CATCH TANK
BLITZ UPPER HOSE
APP BRAKE HOSE
HKS COILOVER SUSPENSION KIT
NISMO ARM TRANBARS LINK
NISMO ARM FRONT UPPER LINK
NISMO ARM REAR A ARM
NISMO ARM REAR UPPER LINK (FRONT)
NISMO ARM REAR UPPER LINK (REAR)
CUSCO PIRO TENSION ROD
CUSCO HICAS LOCK CYLINDER
CUSCO STABILIZER
BREMBO BRAKE SYSTEM F40
QUANTUM RS STREET F/10K R/8K
CUSCO CARBON TOWER BAR
BREMBO BRAKE ROTOR 340mm
BREMBO BRAKE SYSTEM REAR
CLUTCH MASTER CYLINDER
TRIAL BAZOOKA MUFFLER
RAZO TURBO TIMER
RACING WHEEL/SHIFTER
RECARO INTERIORS
FULL TRIAL AERO KIT
17” WORK EMOTION CRKAI WHEEL
YOKOHAMA ADVAN NEOVA TIRE
HID HEADLIGHT
    • https://www.carsales.com.au/cars/details/2002-holden-commodore-ss-vx-ii-auto/SSE-AD-18219062/?gts=SSE-AD-18219062&gtssaleid=SSE-AD-18219062&pageSource=details
    • does anyone know tie rod torque setting and anti roll bar for r34? Is there a workshop which shows various components torque setting?
    • Hi    have purchased pair of eibach wheel spacer as I couldn’t fit set of wheels I bought for my car due to it catching caliper.   I know I need to cut the bolts on my discs so they sit flush with the nut supplied but the nut doesn’t sit all the way into the groove meaning wheel would not directly fit onto the spacer rather the nuts. Any thoughts?   See pic   https://ibb.co/VJK5w5G
    • Nah. There's not shit tonnes of pressure in there. Just drill with a 1.5mm drill or something equally tiny. When the drill goes all the way through thee gas will start to come out, but with such tiny path through the flutes of the drill bit, it won't be at all dangerous. You can be as paranoid as you like from then on. I'd just pull the drill out while keeping my face out of the line of fire. But then, I spend half my time looking into pressurised furnaces. So my risk acceptance is somewhat higher than most!
    • Been needing a new clutch for a while, but holding off because of life tingz and adulting. But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799). Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them). Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
